Senior Member
Superman's Avatar
Yep, Tyson is the best.
I am using the direct-replacement H4 units that do not change the appearance of the car. I'm using 11w highs, which make nighttime into daytime, but I'd like to go even brighter. My relays can handle that, but my wiring may not be able to, so I plan to eventually get super-duper lamp sockets and then upgrade to 130W highs.
If these lights are aimed properly, oncoming traffic will have no issues. Until you forget to dim......
Mocha 1978 911SC. "Coco"
Old 10-05-2004, 03:06 PM
I would rather be driving
jpnovak's Avatar
ARe you getting the Cibie 40 series (tango)? that's what I mounted on my grills. Do you need brackets for them? They are bright enough that you can't see oncoming car lights until you physicaly see the car's lights. No more looking for glare off trees and guard rails. They are perfect! Careful in the twisties. Its easy to blind oncoming cars.
Old 10-05-2004, 03:10 PM
Sports Purpose 911 Driver
mjshira's Avatar
hey Noah, if those are the ones that Dan sells, then yes. Do you have 100w bulbs in them? Where can I get some brackets?
yeah superman, Tyson is cool dude, it would be a blast to live in LA and get to hang out with all the great p-cars fans out there, plus the backroads there are the BOMB.
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 10-05-2004, 04:15 PM
david914's Avatar
Yeah Grady, I wouldn't do that for long with the stock setup, but I'm running a pair of 40 amp relays. Only a few milliamps of current going through the dimmer switch. Good thought on the grounds. I'm sure many people don't even think about that end of the equation!
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 10-05-2004, 06:26 PM
swbsam's Avatar
sam
Self anointed Head of the SSSP
( Super secret seat police )
our motto is : if you've got a bug up your ass, we put it there
67S polo red - gone but not forgotten
87 factory M491 turbo look lagoon green metallic
Old 10-05-2004, 06:38 PM
autoxracer31's Avatar
Send a message via AIM to autoxracer31
silverstars all the way. they work wonders. fog light silverstars too.
Old 10-05-2004, 08:32 PM
any of you guys have the link for the relays?
Old 10-05-2004, 08:47 PM
mjshira's Avatar
Speedy1 just do a search for Dan Stern and you can get everything you need.
What I am looking for now is some brackets for the horngrills as I want to mount lights there, does anyone know where to find some?
Thanks!
Old 10-06-2004, 02:17 PM
jpnovak's Avatar
James, I made my own set. I can make you a set too. You will have to cut your horn grills to make them fit.
Here is a thread where I made my own.
Tell me about early 911 fog lights
Here is another good link with some info from another board member who can make you a set.
horn grill rally light brackets
I have also seen a flat bracket that mounts to the top bolt of the battery box and does not require the grill to be cut.
Vintage 911 restoration question ('69-73)
Old 10-06-2004, 02:38 PM
mjshira's Avatar
thanks Jamie. Trying to do everything I can to get more light on the road when I use highbeam. And its another fun project! I will read these threads and send you a PM. THX
Old 10-06-2004, 02:48 PM
mjshira's Avatar
Jamie I didn't see any pic of a kit that mounts to the battery box?? Do I have to cut the horn grill? Finally, the lamps I am going to run are from Dan and I will have 100w bulbs in them. They may be a little bigger than the stock ones... thoughts?
Old 10-06-2004, 02:55 PM
mjshira's Avatar
swbsam, great pic by the way!
Old 10-06-2004, 02:59 PM
Grady Clay's Avatar
Here is the current thread with a proper relay wiring diagram:
911 Headlight 101
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 10-07-2004, 07:43 AM
mjshira's Avatar
thanks Grady. Ronnie sent me a link to that one too. Seems like several folks are dealing with this issue to.
Old 10-07-2004, 07:45 AM
jpnovak's Avatar
James, clean out your PM box. check the sent and saved folders too.
Old 10-07-2004, 08:22 AM
mjshira's Avatar
cleaned out!
Old 10-07-2004, 08:27 AM
jpnovak's Avatar
Still says full. I will try again shortly. Wait... you have (hot)mail.
Old 10-07-2004, 08:35 AM
mjshira's Avatar
OK, now its cleaned out for real!
Old 10-07-2004, 11:30 AM
skipdup's Avatar
But skip the diode for the high & lo beam on at the same time mod.
1972 911T
1972 911E "RSR"
Old 10-07-2004, 11:41 AM
buttjoint's Avatar
If you replace your H5s with H4s can you use your original trim ring or do you have to paint the ones that come with the H4s Thanks
Old 10-07-2004, 01:51 PM
