H.G.P.'s Avatar
MSD 6A or MSD 6AL both with Blaster?
I believe a new CD Box and perhaps a Blaster may be in order for my 911 (see "No Ignition").
The question is: would the 6A be best for my early 911 ?..., and for either boxes (6A or 6AL), is the Blaster needed/best?
Thank you.
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 10-05-2004, 10:36 AM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
Pretty much the same. The 6AL will have a built in Rev Limiter in it.
The choice is yours.
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 10-05-2004, 11:03 AM
white87911's Avatar
The only difference between the 6A and 6AL is that the 6AL has a built in rev. limiter, which is a nice feature, you can add one to the 6A box at a later date but that will add another small box called "soft touch rev. control".
I would suggest the matching blaster coil as it is designed to work with other MSD products, if you use a different coil that has a different resistance, it can, over time, damage to MSD box.
"Coffee is for Closers"
"Push the button Max!!!"
Old 10-05-2004, 11:05 AM
I run a 6A with the Blaster high vibration coil and a tach adapter in my 67S. All is working very well.
Bob,
59 A coupe
67 911S
04 R1150RS
Old 10-05-2004, 11:14 AM
Bandwidth AbUser
Jim Richards's Avatar
H.G.P., I have the 6A with the blaster coil in my 73E. I rely on the dizzy's rotor-limiter for protection. By the way, I don't think it works well. So, I'm going recommend you get a 6AL.
Jim R.
Old 10-05-2004, 11:15 AM
I use the somewhat square Blaster SS coil pn 8207. It mounts on my elec panel and you may need a longer coil to dizzy wire.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-05-2004, 11:27 AM
