AirBorne!
1989 911 Boxster Brake Conversion
Hi
I'm the new owner of a 1989 911 Carrera Coupe. I don't plan on doing any DE work with the car. I am going to do some mods. I have heard that upgrading the car to the Boxster brake system is a great upgrade.
Any comments or experience in this realm?
Wellborn
Old 10-16-2004, 06:15 AM
Somewhere in the Midwest
MotoSook's Avatar
Unless you plan to track your car, there is no need to change the calipers. Get a set of good high performance street pads and you'll be set. Ferodos are good street pads with less dust than some and I've not had any noise issues with them on the street. Some times the Ferodos are hard to get, but if you run a "brake pad" search you will find lots of choices.
Old 10-16-2004, 06:25 AM
Glasgow 911SC's Avatar
If you were to switch to Boxster calipers you'd need the calipers & adapters. You'd also have to remove the rear P/V to maintain the correct bias. As Souk said, on a Carrera this isn't really an upgrade (cosmetics aside) as you retain the same rotors.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 10-16-2004, 06:36 AM
jyl jyl is online now
jyl's Avatar
Do a search, this has been discussed tons of times.
I happen to have a set of Boxster front calipers and adapters waiting to go on my Carrera - but it's more for cosmetics.
Old 10-16-2004, 08:54 AM
Irrationally exuberant
ChrisBennet's Avatar
I'd say Boxster calipers on a stock rotor are really a downgrade, not an upgrade.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-16-2004, 10:29 AM
Sent you a private message
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 10-16-2004, 11:19 AM
AirBorne!
Thanks guys, think I'll shelve the Boxster idea and just get some sticky pads, do you guys like Padgid pads?
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed
Old 10-16-2004, 01:52 PM
Bill Verburg's Avatar
If you aren't racing Pagid is overkill(but still a great pad, use Blues on the street), save yourself some money and labor(way less cleaning) by using Axxis or PBR Metalmasters(same pad different marketing channels)
Bill Verburg
Old 10-16-2004, 03:19 PM
