Turn signal indicators
So from inside the car both indicators flash so it looks like my four ways are on, but from the outside just the flashers I want are on. I am guessing this means that there is some arcing inside the dash causing both dash indicators to light up? Does anyone have any advice or experience with this?
Mike
PS. A photo of my new Winter beater.
1972 911T Targa
1994 Volvo 850 Wagon
1988 BMW 635 CSi
Old 10-10-2004, 06:35 AM
jluetjen's Avatar
I've got the same problem that I need to fix this winter. My understanding is that it is most likely a bad ground in one of the light clusters at the corners of the car.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 10-10-2004, 08:01 AM
I believe that indicates that you've got a blown bulb or bad ground in one of your turn signal assemblies. Flip it to one side and then the other inspecting each of your signal indictors outside the car. One will probably not be working and that should zero you in on the culprit to start with.
Dan O
84' 3.2 Targa
Old 10-10-2004, 12:54 PM
That was my first guess, so I had the car idling and checked turn signals both directions with the lights on and off and all 4 times, both indicators were flashing inside the car and outside the car everything looked as it should.
Mike
1972 911T Targa
1988 BMW 635 CSi
Old 10-10-2004, 03:04 PM
Erakad's Avatar
Haven't tested it, but I've also been told this happens when using aftermarket turn signal relays (mine does the same and it's aftermarket). Any tructh?????
Rob
Black 1983
911 SC Coupe
Old 10-10-2004, 06:48 PM
