hkspwrsche's Avatar
Price check- lower and align an SC?
Just wondering what a reasonable price would be. East coast in Richmond, Va.
Thanks,
Harold
Old 10-11-2004, 11:22 AM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
An alignment should run about $175-200. Lowering is a different story. If your back has to be lowered more than ~1/2" that you will have to get the rear t-bars re-indexed and that can run a lot of labor. I'd suggest get them close yourself and then bring them in for the fine tuning.
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 10-11-2004, 11:32 AM
jdowty3's Avatar
A 4 wheel alignment in Dallas runs about $150. The lowering is going to vary due to the time it takes to get it right. The guys I have talked to say you need to adjust, then a short drive to get the suspension settled, then measure, and do it again, and usually again, etc..... Time = $, more time = $$$
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 10-11-2004, 12:05 PM
hkspwrsche's Avatar
This one will probably need reindexing. I can fit my fist upright between the tire and rear wheel opening and I dont have small paws.
Thanks,
Harold
Old 10-11-2004, 12:22 PM
disband
juanbenae's Avatar
oohhhh ahhhh big H with the monster paws........
Old 10-11-2004, 12:47 PM
adamred's Avatar
My cayenne-height SC was lowered to euro and aligned for $380 all in by a mechanic
$250 for the lowering
$120 for alignment + taxes, etc....
Adam
Adam,
2019 BMW 540i
Old 10-11-2004, 12:48 PM
Just had my 930 aligned Friday. Cost: $200 Chicagoland Independent
Old 10-11-2004, 03:48 PM
Just had my Carrera lowered and aligned here in the UK. Was 5-6 hours labour (not sure of the exact time from the invoice as it included some other work). This included re-setting teh spring plates on the torsion bars at the rear.
"Racing is Life. Anything that happens before, or after, is just waiting"
1988 Carrera 3.2 Sport Coupe - my mistress
2012 BMW F11 touring - the dog bus!
2017 VW T6 Transporter - the holiday bus/workhorse
Old 10-12-2004, 05:30 AM
rip78sc's Avatar
Ok guys, ignorance is bliss, what's wrong with getting a front end computer alignment at say, Sears, for $59.99????
________________
78 911 SC Targa
11 Cayenne Base
15 Macan Turbo
Old 10-12-2004, 06:56 AM
Irrationally exuberant
ChrisBennet's Avatar
If you're going to change the ride height you really should have it corner weighted at the same time.
I get mine aligned by a certain guy at a local tire place for $100. I kept him company for the first few times until I felt comfortable with his work.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-12-2004, 07:45 AM
hkspwrsche's Avatar
UK Carrera do you mean re indexing the torsion bars or actually just adjusting the spring plates?
thnks
Harold
Old 10-12-2004, 09:57 PM
Re-indexing the torsion bars.
Old 10-13-2004, 10:57 AM
Send a message via Yahoo to 911Brian
I just went through the same thing, although I lowered it myself. It wasn't that bad just took a little time and the only thing I have done to a car before that was replace an alternator. My SC was at the US ride height and I lowered it to the Euro height. 25 in rear and 25.5 in front. Measurments are from the ground to fender lip.
I took in to get a 4 wheel alignment and corner balance and the mech told me my ride height was "nuts on". Not too bad for a first timer. The alignment and CB cost about $300. If you have the space and time, you should try and lower it yourself.
86 Carrera Red/Black
80 SC Coupe Silver/Black (gone but not forgotten)
Old 10-13-2004, 11:24 AM
hkspwrsche's Avatar
How about you PM me your number for an emergency hotline if I give it a try and run into a snag! What part of richmond are you in? Did you use an angle finder, etc..? or just wing it?
Who do you use for a mechanic locally?
Harold
Old 10-13-2004, 11:28 AM
You have a PM!
Old 10-13-2004, 11:54 AM
adamred's Avatar
My lowered before and after
Hi Harold, I responded to your PM.
See my before and after. I didn't go lower the euro and still got a nice result.
Adam
Adam,
2019 BMW 540i
Old 10-13-2004, 12:40 PM
adamred's Avatar
I like this low view the best...
Adam,
2019 BMW 540i
Old 10-13-2004, 12:41 PM
hkspwrsche's Avatar
Adam,
That's a lot of adjustment. Same as I need. You say the torsion bars were not reindexed in the rear? Can you confirm that with the tech that did the lowering?
thanks,
Harold
Old 10-13-2004, 12:43 PM
adamred's Avatar
Sure thing, I'll call him in the morning.
Adam
Adam,
2019 BMW 540i
Old 10-13-2004, 01:58 PM
adamred's Avatar
Hi Harold-
Yes my torsion bars were re-indexed...My guy has been doing them since the SCs came out so for him it goes very quickly but as he just told me you never know what's going to happen when you start taking things apart....
Adam
Adam,
2019 BMW 540i
Old 10-14-2004, 06:32 AM
