randyrap's Avatar
Using Gunson CO Tester
I recently purchased a Gunson CO tester and want to make sure I'm using it properly for testing my 83 911SC. The Cat has been replaced with a by-pass pipe.
JW says the optimum CO should be 3.5. Is this at idle or at a certain RPM. Should the test be done at idle? How about the O2 sensor? Should it be disconnected?
Thanks in advance ............................... Randy
83 911 SC Coupe ''Sunroof Delete''
Are we having fun yet ?
Old 10-12-2004, 03:02 PM
walt's Avatar
I set mine at 3.5% at idle. I do not run an O2 sensor.
Walt
82SC 3.0
81SC 3.6
Old 10-12-2004, 03:20 PM
Virginia Rocks!
VaSteve's Avatar
You will also need a 1/4" outer diameter tube to get into the cat bung. I went to Home Depot and found some copper ice maker tubing that worked great.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 10-12-2004, 04:49 PM
randyrap's Avatar
No need for the extra tube as I replaced the Cat with a by-pass. Readings can be taken directly within the tail pipe.
Randy
Old 10-12-2004, 07:28 PM
Lorenfb's Avatar
Set the CO at about 1.5 to 2.0% before the CAT without the O2 sensor connected
with the RPM at 2000 to 2500. The 3.5% is a little too rich for the SC with CIS
injection.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 10-13-2004, 12:09 AM
