limble's Avatar
79 SC runs rough
It acts as if one cylinder isn't firing. I pulled the air cleaner off, turned the ignition to on pushed the flapper valve for a few seconds. Heard it squeal. Did this several times. Still didn't help.
Tailpipe sooty.
Thanks,
Mike
When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE.
1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation)
Old 05-08-2005, 02:17 PM
How I find a one cylinder miss is to use an inductive timing light and check all the plug wires for a spark. If the plug isn't firing or maybe fouled, it won't trigger the light. Not grounding, no spark, etc. I check them all at idle and throughout the rpm range.
If you find one cylinder that is missing spark, then you can check your plugs, your wires, the dizzy stuff, etc.
If you dont, then maybe check your fuel system.
Just a very quick and basic place to start.
Scott Clevenger
1989 BMW 325ix 190K
1981 911SC 110K miles
http://www.pelicanparts.com/gallery/clevy70911T/
Old 05-08-2005, 10:23 PM
ruf-porsche's Avatar
Buy a pair of insulated spark plug wire pliers and pull each spark plug wire from the distributor until you find a cylinder were pulling the wire doesn't change the rpm of the engine. That the dead cylinder. Unless you feel like getting shock, the insulated pliers are a good investment. I keep mine in the glove compartment.
The timing light may work, but if you have a bad injector, the spark plug will still fire. My was a bad injector.
Old 05-09-2005, 05:48 AM
Pull your plugs. The plug/s that come out black is it.
How old are your ignition cables?
Joe
Redwood PCA since 1976
Old 05-10-2005, 08:45 AM
