Sports Purpose 911 Driver
hey HGP, good points (I read your old post so I know you have been where I am now) I will follow that. I don't know what you mean by dizzy?? The dis. is new, I just changed the rotor, the points have 5k on them, all the wires have been check, connections cleaned as needed, etc.
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
pelicantalk
dizzy = ignition distributor
thanks Ronnie!
heading out to the car in a few minutes, battery on the charger now.
well, still not running. BUT! ;-) I am still swinging! I found that the plugs and the points were gap'd too wide. I have fixed that. I left the plugs out in favor of letting the car "breath" as per Grady. Tomorrow I will static time the engine and then try the starter fluid again. I appreciate everyone's support.
hey guys, I woke up this morning at 4:30 with my brain thinking about all this stuff! I am excited to get home later again see if we can get her running. The quote of the day is:
"It is not the critic who counts; not the man who points out how the strong man stumbles, or where the doer of deeds could have done them better. The credit belongs to the man who is actually in the arena, who's face is marred by dust and sweat and blood; who strives valiantly; who errs, who comes short again and again, because there is no effort without error and shortcoming; but who does actually strive to do the deeds; who knows great enthusiasms, the great devotions; who spends himself in a worthy cause; who at the best knows in the end the triumph of high achievement, and who at the worst, if he fails, at least fails while daring greatly, so that his place shall never be with those cold and timid souls who neither know victory nor defeat." President Theodore Roosevelt April 23, 1910
I would rather be driving
Well said.
If you have the dist out of the car to set static timing, that would be a good time to install the Optical conversion. It is much easier to do this installation with the dist. out of the car.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I have no plans to remove the dist from the car. Can I not static time it (since I don't think it is that far off) with it in the car? I plan on following Warren's directions to the letter...
Yes, you can set timing without removing the dist. The same procedure is used if the dist stays in the car or was removed.
it's RUNNING!!!!!!!!!!!!!!!!!!!
Thanks everyone. Grady your tip about leaving the plugs out worked! Warren, the pics were golden and the instructions were, ahh, "James proof" ;-) Gotta jam, need to drive and don't want to let it run out of fuel
![]() That's great to hear. Is this the new ignition running? Now that it runs you may want to plug the old one in to see if that was the problem. Of course, drive it a bit first.
I have not changed the points to electronic yet. I did take my time and set the points EXACTLY right. As well as the static time. I didn't even need much of the starter fluid.
I appreciate all of you fellas, especially for not flamming me for all the novice questions. Next step is to get the timing set with the light, another new thing to me but I feel confident about it now :-D
didn't you convert to the Permatune system with the built in coil?
The timing will be a piece of cake now. Just make sure the inductive pickup on points the correct direction on the plug wire. Match up the arrow and you will be fine. I usually pull 12V from the 3 fuse holder on the rear console and ground at the stud by the coil. No novice questions here. not asking the question just leads to more problems.
Good call on NOT changing yet. NOW when yu change, you will KNOW if you screwed up putting the optical parts in...
Ask me how I know!~ I do like my CRane optical trigger and MSD setup
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
yeah I have that Jamie. Could you expand a bit on how to time it again? I know where to get power and ground, its that second point you made that I missed, thanks.
I hear ya Jake!
Sure, I am assuming your new timing light has an inducting pickup. This will be a clamp like thing on the third (not power or ground) wire from the light. This works by a coil of wire that converts the pulse of voltage through the spark plug wire into a trigger which fires the light. When the plug fires, the light strobes.
This inductive pickup usually has a clamp side that slides back opening the hole in the pickup. This coil is also directional so you must orient it correctly. There should be an arrow on the clamp that points in the direction of spark travel. This arrow will point down the plug wire towards the plug. Place this clamp on the #1 plug wire. When the engine is running and the power and ground connected the lamp should fire. Careful with the wires near the fan. aim the light at the lower edge of teh fan housing where it meets the case. There should be a mark there. when the light fires you should see some marks on the crank pulley which is directly below. loosen the dist fixing bolt just slightly. When you rotate the dist, the relation between the rotor/cap and the crank shaft are changed. This causes the trigger to move in an advance or retard manner. Advance is when the plug fires before the piston reaches top dead center in the cylinder. Retard is when the plug fires after the piston reaches TDC. You will have to find the timing specs for your engine. They should be on a plaque on the fan shroud strap. I usually set my engine to 30 BTDC at 6K rpm. Look at the timing marks on the pulley. There should be 4. IIRC, These will be 5 ATDC, TDC, 15 and 25 BTDC, but each pulley is different. Use the marks to set the timing spec. Just rotate the dist while the light is flashing and line up the lights for a given engine speed.
Guest
Posts: n/a
YOU ARE NOT EVIL ENOUGH YET!
Guest
Posts: n/a
Guest
Posts: n/a
Glad to hear that she is back and running! Do you have ant current pics on the car?
