accelerator on 83 sc has too much play
Hey out there anybody have any idea on this ?
when I push down on my go pedal it seems there's too much slack before it has any effect , nother words I have to push pedal down a bit,before I feel any resistance or effect on the engine rpms
I saw all the posts about the bushings by the pedal cluster, would those be the ones that would effect the slop in the pedal?
any ideas would be great.
Don Smith
dps 83 sc targa
Old 10-24-2004, 05:26 PM
GB83SC's Avatar
Don,
You can adjust the linkage at the rear or the motor on the left hand side. I dont remember if there is a adjustment just under
the gas pedal. I did a rear adjustment on my car after a engine drop, works great now,
Good luck.
George
My Owners Gallery Page
1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running.
1995 BMW 525I
2001 Highlander- kid mover
Old 10-24-2004, 06:43 PM
MichiganMat's Avatar
Send a message via AIM to MichiganMat
I have the same issue.
I rebuilt my cluster, that helped a lot. The bushings were flopping around and were worn out.
I usually use the manual throttle lever to take up the rest of the slack.
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
'99 LR Disco 2, gone but not forgotten
Old 10-24-2004, 07:36 PM
smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
Not only do you need to adjust it to get rid of the slack but you also need to check at the throttle body. You want to make sure you are getting full Wide Open Throttle when the pedal is to the floor. Best FREE horse power you can get is from a properly adjusted linkage.
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 10-24-2004, 10:26 PM
