hkspwrsche's Avatar
SC- front camber help needed!
Car is lowered and even but...
The front camber is too negative. besides the slots in the top of the strut. What can I do to bring the front in more towards positive ????
Harold
Old 10-28-2004, 03:53 PM
hkspwrsche's Avatar
The front camber is 1.5 negative on both sides but this is a street only car.. The rear is only .5 negative to keep the tires from wearing out...
Like to get the front more positive one degree! outa room on the slots..any ideas let me know.
**Is it safe to grind the slots out some?**
Harold
Harold
Old 10-28-2004, 04:08 PM
Chuck Moreland's Avatar
This is a new product that I've recently introduced and it's available through Pelican, in queue though not in the online catalog just yet. Call and ask for it.
It's an offset ball joint. The pin is offcenter in the housing, thereby changing the camber. The motivation for the product was to allow track cars to get more negative camber.
Racers are familiar with the trick of lengthening control arms to increase camber and track. This does the same thing, without breaking out the welder.
It can be turned around for your needs; more positive camber. To turn it around, you will need to file a notch for the control arm key - easy to do.
Chuck Moreland - elephantracing.com - vonnen.com
Old 10-28-2004, 04:22 PM
hkspwrsche's Avatar
So many 911's are lowered to the normal 25.5 front and 25 rear that I thought there is something more going on here.. something that could be adjusted more!! Maybe someone else has had this issue??
Harold
Old 10-28-2004, 04:58 PM
This is a common problem with lowered cars that want to keep "street" camber settings.
You can safely notch the bolt holes to get a little more positive. you might get 1/4 degree this way. But don't grind out the big center hole that the strut top passes through.
Old 10-28-2004, 05:05 PM
hkspwrsche's Avatar
What specs are people running on the street right now? I was under the impression it would be the same as a euro car and was going back to normal for what Porsche intended... The Bruce Anderson book said that US bumper/ride height had adverse effects on the alignment settings...
Harold
Old 10-28-2004, 06:12 PM
450knotOffice's Avatar
I've got the same problem. My mech at Hergsheimer feels I probably have a slightly bent left strut because he can't decrease the camber anymore than the -1.5 degrees that it's at right now. He has no problem with the other side.
-Scott
Old 10-28-2004, 06:13 PM
hkspwrsche's Avatar
Mine is both.....run all the way out it gets to -1.5 after lowering it.. no bends..
Harold
Old 10-28-2004, 06:18 PM
You might try adjusting your wheel bearings if they feel like they have a lot of play.
Joe
Old 10-28-2004, 06:54 PM
hkspwrsche's Avatar
It seems that I hear people asking to get more negative when I do a search. I havent run across to many that have this issue with the camber being to negative although it makes sense that it might be an issue.
Harold
Old 10-28-2004, 08:35 PM
It is only an issue if you insist on having your car aligned to factory spec.
Joe
Old 10-29-2004, 01:19 AM
It's also possible that the spindle is beginning to break off the shock shaft...or has been bent up in a major "bump"......
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 10-29-2004, 05:45 AM
hkspwrsche's Avatar
Seems odd that it would do that the same amount so that both have the same amount of adjustment. I guess it's possible.
thanks
Harold
Old 10-29-2004, 06:30 AM
Harold,
You won't want to hear this, but the easiest way to get more positive is to raise it until you get it where your camber is acceptable.
Ride height, looks, handling...it's all a trade off.
Cheers,
Joe
Old 10-29-2004, 01:52 PM
hkspwrsche's Avatar
Actually that was my first thought but, I didnt want to mess with the ride height anymore! (ever again!)
I will see if it's going to be a problem and maybe I'll end up moving it up a little.
thanks
Harold
Old 10-29-2004, 02:16 PM
