Probably the dumbest question I've asked, but how the heck does one replace the air filter in a 3.2 Carrera? I unsnapped the clamps on the housing, but the air intake just kind of separates from the front and doesn't appear to be able to separate completely from the rest of the housing. Is it supposed to? Right now, I unclamp it and there's not enough room to pull the old air filter out. Ugh! I must be missing something.
Driving member
Steve, there are 2 more clamps on the backside. Stand on the drivers side of the engine bay and reach around the back of the
flowmeter/fuel injection to reach the back 2 clamps. No worries everyone has a problem with it first time.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Aha! Thanks! So the air intake "horn" fully separates from the rest of the housing?
Driving member
Yes, it comes off completely
For clarity...the "horn" or trumpet is part of the front housing that comes off all in one piece...the horn does not separate from the front removable cover....
hint....do a "cup" conversion. Once the lid is off..hacksw the entire front face off leaving a 1" wide band that holds the filter in-place. Now you can "See" ( not just "feel") the four clamps....and provides a cleaner access to the right side of the engine for valve adjustments, oil filter changes, etc... Sounds better too... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Here's a cover with associated clips:
Warren & Ron, may you rest in Peace. |
I think you may get into smog issues here if you modify the air filter housing. Seems ridiculous, but another Pelican here had issues with the visual on his '76 911s 3.0.
Don't have the absolute "ruling" on this, just something to consider. -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
What a funny looking placebo.
-Joe |
Yep that would be me. I was told cutting the airbox was a "PVC modification" and was told to turn around and go home. Didn't even bother to run the car. Doesn't do anything for performance, but it does deepen the exhaust note a bit.
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
"but it does deepen the exhaust note a bit"
Might just hear the intake note a bit more. -Joe |
Thread Tools | |
Rate This Thread | |
