jyl jyl is online now
jyl's Avatar
Headlight Not Working
Grumble, grumble.
Pass side low beam is not working. All other headlight functions working fine (pass side high beam, driver's side low and high beams). H5 lights. Bulb looks fine. No current getting to the low beam contact in the socket. Fuse is fine. Haven't checked the relay yet (have the sucro kit) but not sure how a relay problem would sideline only the pass side low beam. Hope don't have a break in the wiring, somewhere in the harness. I'm so busy at work right now, didn't really feel like tracing an electrical problem.
Oh well, I'm sure it is trivial. Just felt like grumbling.
Old 11-09-2004, 07:26 PM
JCR JCR is offline
You said the fuse is fine, but did you check it's contact? A simple twist may solve it (followed with a wire brush and a touch of di-electric grease).
Jared
Met Silver '73 911S #0793
IrishGreen '69 912 #0602
Early S Registry #454
R Gruppe #391
Old 11-09-2004, 08:18 PM
djmcmath's Avatar
I've been through this one twice with my H-4's (with Sucro relays). The first time, quickly replaced bulbs, didn't fix the problem. Spent several long hours troubleshooting with electrical diagram and multimeter, to no avail. Finally resolved to dismantle, clean, and rewire the entire headlight system start to finish -- and found that the problem had disappeared.
The second time was no better. I have no idea what part I jiggled, pulled on, cleaned, rewired, or magically corrected, that did the job -- I'm now convinced that it was my realization that I had been beaten and needed to rewire everything that did the job. .... So make a resolution to tear out all of the wires associated with the headlights and redo the whole thing, correctly. Get the tools and parts. Stage them in your trunk, where the wiring gremlins will be able to see them. If that doesn't fix the problem, I don't know what will.
Good luck,
Dan
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 11-09-2004, 08:50 PM
