Poll: What have you done to your engine?
Poll Options
efhughes3's Avatar
Upgrading Motor-What have YOU done?
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 11-13-2004, 05:44 AM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Re: Upgrading Motor-What have YOU done?
Nothing, it's bone stock.
Ed, are you STILL on the fence?
Ralph
EDIT: Waiting for the onslaught of 3.6L conversion guys to swamp us rebuild folks.
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 11-13-2004, 05:53 AM
Designer King
Paulporsche's Avatar
I got rid of the old, tired 77 2.7L (160 hp) about 13 yr ago and replaced it w/ a rebuilt 80 3.0L enlarged to 3.2L twin plug using new pistons and revised cam. I kept the CIS and the old points distributor for the time being. I added SSIs and a Dansk 2in-1 out exhaust. Some day I may install the dual plug distrib to take advantage of lower octane gas and PMOs, but for now I'm enjoying the smooth 230 hp of this setup and the ease of working on the CIS. It's an old school, low tech solution but this setup is very strong in my 2500 lb chassis, and I have put about 75,000 mi on this engine. I use Sunoco Gold (94) and Mobil 1 15W50.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-13-2004, 05:58 AM
Install425's Avatar
Rob,
88 911 Turbo
Old 11-13-2004, 07:17 AM
Non Compos Mentis
Swapped a stock 3.2 into the 1973 coupe.
more horsepower and torque that a built 2.4, and has the reliability of a factory engine.
Old 11-13-2004, 08:40 AM
Where's the "Converted to Turbo" option?
Old 11-13-2004, 09:44 AM
Unregistered
sammyg2's Avatar
I agree with Colin, turbo option..............
Old 11-13-2004, 09:51 AM
efhughes3's Avatar
Sorry I missed the Turbo conversion choice.
Ed Hughes
2015 981 Cayman GTS
Old 11-13-2004, 10:41 AM
iamchappy's Avatar
TURBO
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 11-13-2004, 10:44 AM
Randy Webb's Avatar
3.2L 1986 motor modified in a 1973.5 911T
~ 250 hp at 6,300 rpm; ~ 210 torque at 3,200 – very flat from 2,500 up to 6,300
split the case halves and balanced crank, etc.; main bearings were great (re-used); everything fine on engine
Compression ratio 10.2:1
JE pistons with JE wrist pins; three different ceramic coatings on pistons – anti-friction coating on skirts; oil retention coating on underside; and coating on top to let carbon slide off so it won’t build up
stock OEM (Goertz?) piston rings – was told Total Seal rings are hard on bores and slow to seat
Cyl. heads cc’d fine – all very close to each other and well within spec.; heads flowed well on flow bench
993 intake valves (larger, and about 24 g. lighter than stock, about the same as the CS intake valves)
valve seats are cut with radii, not with sharp angles – this NASCAR trick is worth about 5% more hp as doesn’t cause as much turbulence to inlet air flow
Aasco (Aase??) valve springs (have 90 lb. spring rate vs. 65-70 for stock, main improvement is they won’t break)
Aasco (Aase??) Ti retainers; and Aase steel keepers
Twin-plugged with 964 dual distributors with SC distributor inards in main dist. for magnetic reluctor and advance mechanism
40 mm PMO carbs; SSIs; ports celaned up a bit but otherwise not modified
MSD 6AL CD ignition with 2 MSD Blaster Coils
I modified a 911 type trans. to fit because I like the shift pattern and it saves a little bit of wt.; the engine has a flywheel adpater on it for this trans.
I made an adapter plate so the trans could use the 915 type support bar with replaceable rubber mounts.
I did not modify the trans. with the Al billet int. plate. I baby it in 1st gear and hopefully can get a couple of years out of it while I gather my energies for more trans. mods.
This is a hot street engine, not a race car. It is faster than a 964....
Old 11-13-2004, 11:43 AM
charlesbahn's Avatar
Turbo, Turbo, Turbo, and Big Intercooler.
"Igneous Aquam et Laudi semper"
Carl Muckley
Old 11-13-2004, 11:47 AM
turbo
Old 11-13-2004, 12:46 PM
efhughes3's Avatar
Goddangit, there certainly appears to be a TURBO epidemic!!!!!
I may have to rethink all of my plans. Sorry again for not including you guys...I'll start another poll.
Ed Hughes
2015 981 Cayman GTS
Old 11-13-2004, 12:48 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
1978 3.0 SC into a 1974 911s. 20/21 cams, ssi's, two in two out banana muffler from TRE. MSD 6al and coil, nology wires.
Soon to be my engine! dad is getting a 3.2 with ITB's and EFI and some other goodies in the mix, maybe bigger p's and c's
74 911s neverending story. two feet and a jetta for now.
Old 11-13-2004, 01:03 PM
rkh3's Avatar
1979 911 3.3L turbo cabriolet
K27 turbo w/sc cams, matching intercooler
Insanity-doing the same thing over and over and expecting different results
Old 11-14-2004, 05:00 AM
WydRyd's Avatar
From bone stock 3.2 Carrera to Stage 3 Protomotive Turbosystem developing ~550-600HP
Future plans could well be a Twin Turbo setup & Autronic injection
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 11-15-2004, 04:20 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
2.2 S into a '66
3.2 into an SC
3.3 C2TURBO into an SC
3.6 into a '72
Marc
Old 11-15-2004, 04:24 PM
