Upgrading Motor-What have YOU done?
What have you done to your engine?
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Doesn't want/need a 3.6L
Re: Upgrading Motor-What have YOU done?
![]() Ed, are you STILL on the fence? Ralph EDIT: Waiting for the onslaught of 3.6L conversion guys to swamp us rebuild folks. Last edited by Carrera3.5L; 11-13-2004 at 07:19 AM.. |
Designer King
I got rid of the old, tired 77 2.7L (160 hp) about 13 yr ago and replaced it w/ a rebuilt 80 3.0L enlarged to 3.2L twin plug using new pistons and revised cam. I kept the CIS and the old points distributor for the time being. I added SSIs and a Dansk 2in-1 out exhaust. Some day I may install the dual plug distrib to take advantage of lower octane gas and PMOs, but for now I'm enjoying the smooth 230 hp of this setup and the ease of working on the CIS. It's an old school, low tech solution but this setup is very strong in my 2500 lb chassis, and I have put about 75,000 mi on this engine. I use Sunoco Gold (94) and Mobil 1 15W50.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 11-13-2004 at 10:01 AM.. |
Rob, 88 911 Turbo |
Non Compos Mentis
Swapped a stock 3.2 into the 1973 coupe.
more horsepower and torque that a built 2.4, and has the reliability of a factory engine. |
Where's the "Converted to Turbo" option?
993 |
Unregistered
I agree with Colin, turbo option..............
Sorry I missed the Turbo conversion choice.
TURBO
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 |
3.2L 1986 motor modified in a 1973.5 911T
~ 250 hp at 6,300 rpm; ~ 210 torque at 3,200 – very flat from 2,500 up to 6,300 split the case halves and balanced crank, etc.; main bearings were great (re-used); everything fine on engine Compression ratio 10.2:1 JE pistons with JE wrist pins; three different ceramic coatings on pistons – anti-friction coating on skirts; oil retention coating on underside; and coating on top to let carbon slide off so it won’t build up stock OEM (Goertz?) piston rings – was told Total Seal rings are hard on bores and slow to seat Cyl. heads cc’d fine – all very close to each other and well within spec.; heads flowed well on flow bench 993 intake valves (larger, and about 24 g. lighter than stock, about the same as the CS intake valves) valve seats are cut with radii, not with sharp angles – this NASCAR trick is worth about 5% more hp as doesn’t cause as much turbulence to inlet air flow Aasco (Aase??) valve springs (have 90 lb. spring rate vs. 65-70 for stock, main improvement is they won’t break) Aasco (Aase??) Ti retainers; and Aase steel keepers Twin-plugged with 964 dual distributors with SC distributor inards in main dist. for magnetic reluctor and advance mechanism 40 mm PMO carbs; SSIs; ports celaned up a bit but otherwise not modified MSD 6AL CD ignition with 2 MSD Blaster Coils I modified a 911 type trans. to fit because I like the shift pattern and it saves a little bit of wt.; the engine has a flywheel adpater on it for this trans. I made an adapter plate so the trans could use the 915 type support bar with replaceable rubber mounts. I did not modify the trans. with the Al billet int. plate. I baby it in 1st gear and hopefully can get a couple of years out of it while I gather my energies for more trans. mods. This is a hot street engine, not a race car. It is faster than a 964.... |
Turbo, Turbo, Turbo, and Big Intercooler.
"Igneous Aquam et Laudi semper" Carl Muckley |
turbo
Goddangit, there certainly appears to be a TURBO epidemic!!!!!
I may have to rethink all of my plans. Sorry again for not including you guys...I'll start another poll.
1978 3.0 SC into a 1974 911s. 20/21 cams, ssi's, two in two out banana muffler from TRE. MSD 6al and coil, nology wires.
Soon to be my engine! dad is getting a 3.2 with ITB's and EFI and some other goodies in the mix, maybe bigger p's and c's
74 911s neverending story. two feet and a jetta for now. |
1979 911 3.3L turbo cabriolet K27 turbo w/sc cams, matching intercooler Insanity-doing the same thing over and over and expecting different results |
From bone stock 3.2 Carrera to Stage 3 Protomotive Turbosystem developing ~550-600HP
![]() Future plans could well be a Twin Turbo setup & Autronic injection
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Insert Tag Line HERE.....
2.2 S into a '66
3.2 into an SC 3.3 C2TURBO into an SC 3.6 into a '72
Marc |
