Britain Smith's Avatar
Custom Gauge Ideas...what you got?
I have gotten pretty far in the wiring of the car and I am now at the point of figuring out which wires I need to run for the gauges. Yes, I know this is a 912 but since it will have a type-4 engine I need a CHT gauge and/or possibly a EGT gauge. I have the combo oil temp/pressure gauge as you can see in the picture. I also have a boost gauge for the turbo side of things. I was thinking of dumping the oil level indicator in the far left gauge since I am not running a dry sump and therefore do not have a external oil tank. Does anyone know if there is a CHT gauge or a EGT gauge that I can get custom fit in there by Palo Alto Speedo?
I also have another tach that is the 930 style with the boost gauge in it, I could have them redo that for another gauge also. I wonder if it would be possible to integrate a air/fuel ratio gauge in there? I have seen people put volt meters in there, do you think that a volt meter is necessary? Share you ideas and show me what you got...
-Britain
This is the gauge that I want to change:
Here are some gauges off Palo Alto Speedometer and Hollywood Speedo sites:
'69 912 w/ 2.3L Type-4 Turbo Engine
'74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans.
'80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks
-- www.britainracing.com --
Old 11-14-2004, 12:43 PM
Grady Clay's Avatar
Britain,
Looks nice. Why not use the green & white faces for an early ’66 look with the body color painted dash? You will get serious double-takes when people realize what the gauges are – part of the fun.
In addition to gauges, I am a fan of warning lights. I have an adjustable 35 PSI oil light (917 P/N), broken fan belt, over temperature lights, and low fuel pressure. These can easily be incorporated in the gauges. A voltmeter is a useful diagnostic tool.
With a turbo type-4, why not a dry sump? All the parts are readily available and you can even use a modified 911 oil sump tank with the VDO/Porsche oil level gauge.
What is your planned use? Will it use gasoline or methanol? If on gas, you should consider the “Rubbermaid Solution” on this Forum.
Cool project.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 11-14-2004, 01:15 PM
I copied from this BBS
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-14-2004, 01:16 PM
RETIRED
Joe Bob's Avatar
Hmmm, that looks familiar....
2012 ML350 3.0 Turbo Diesel
Old 11-14-2004, 01:20 PM
Originally posted by Grady Clay
Britain,
Cool project.
Best,
Grady
It is a '69 912 and therefore came with the later style gauges...also I already have most of the gauges that I need.
I will incorporate several lights in the dash for warning indicators. These are very inportant to me for intense driving sessions where the eyes are one the road.
I am going to be running a Carrera fender oil cooler, but keep it wet sump with a deep sump mount.
What is the rubbermaid solution?
-Britain
Old 11-14-2004, 01:35 PM
RETIRED
Joe Bob's Avatar
BTW.....that pic is of "Red"....the guage I had made was from an aircraft company. Check the post....sorry can't remember who did it for me....was reasonably priced.
Old 11-14-2004, 04:15 PM
On a great circle route
xlr8's Avatar
I like this idea-
Russ
Old 11-14-2004, 05:23 PM
The mouting of the Valentine 1 in there is pretty slick...I like it. I think it would look even better with a black faced tach. Anyone have any idea how they did that?
-Britain
Old 11-15-2004, 07:58 AM
concentric's Avatar
-Britain
Or even better, who did it...
JCM
Stuff of marginal consequence:
- 1974 911"Carerra" sunroof coupe
Old 11-17-2004, 12:20 PM
Here is the page that shows the installation...a friend with a 993 sent this to me.
www.p-car.com Radar Install
I might try it on a old crappy tach that I have to see how it goes.
-Britain
Old 11-17-2004, 12:31 PM
concentric's Avatar
thanks, man.
JCM
Old 11-17-2004, 01:17 PM
