Automotive Monomaniac
Emission's Avatar
Where do I find this type of "trim" for metal?
I've removed my fog lights, and I'd like to clean up the now exposed openings. My thought is to use a black rubber "trim" around the perimeter (as they are both to remain open for cooling).
I am looking for that rubber "trim" (with metal banding inside) that is used to cover exposed sheet metal so it won't cut or abrade. It is black and is shaped like a "C" so it self-clamps over the edge of the metal. I assume it is sold by the foot.
What is it called? Where can I find it? Sorry I don't have a picture.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 11-14-2004, 07:55 AM
how about the stuff used around 911 opening quarter windows, on the body side.
206 637 4071
Old 11-14-2004, 08:07 AM
Emission's Avatar
I guess that would work too.
Where do I either? Automotive supply shop? Upholstery shop? Harware store?
Old 11-14-2004, 08:20 AM
dealer. probably pretty cheap. check it out on a car to see if it will work and if it's long enough.
206 637 4071
Old 11-14-2004, 08:25 AM
DByers's Avatar
Mike,
We use some stuff that is a rubber C-channel for panelboards and such (electrical). I could check tomorrow when I get in the office and see if I have any in the feild. You wouldnt need but what, 4' ? Mainly for 16g metal. The other thing you could try is heat shrink tubing. Cut in half and break out the dryer to shrink it on to the metal. Just do it inch by inch so the tubing shrinks around the metal and not on its self. You can find the shrink tube at most Radio shacks and probably Home Depot. They may also have the C-channel barrier.
Dan Byers
Old 11-14-2004, 08:27 AM
Emission's Avatar
I found some on my other car. In the photo it is white (I'd prefer black) and it's used as trim around the sunroof.
Old 11-14-2004, 08:31 AM
Emission's Avatar
Originally posted by DByers
"...I could check tomorrow when I get in the office and see if I have any in the feild..."
Dan,
I need it by tomorrow night as my car is on display at a car show on Tuesday.
Let me see if I can find it locally, and I'll look into the heat shrink tubing too - good idea.
If nothing turns up, I'll get back to you.
- Mike
Old 11-14-2004, 08:33 AM
maxnine11's Avatar
Mike, how about using black door edge guard material ?? Usually has its' own adhesive built in. Cheap and easy to find at your local Autozone type place.
max
Old 11-14-2004, 08:49 AM
david.avery's Avatar
Try this stuff, aircraftspruce is awesome
http://www.aircraftspruce.com/catalog/appages/grommetedging.php
David Avery
05 Lotus Elise (sold) | 08 BMW 135i
visit FocusedE, my e-business company | visit Spyderclub
Old 11-14-2004, 09:10 AM
black rubber squirter hose sliced open with a razor will work in a pinch.
206 637 4071
Old 11-14-2004, 09:24 AM
Emission's Avatar
All great ideas... but this is a "pinch" so I am going to try it.
Old 11-14-2004, 10:33 AM
www.cleanseal.com has it
Jerry
Old 11-14-2004, 10:34 AM
Emission's Avatar
Jerry
Cool, I can order some for a long-term fix.
Old 11-14-2004, 10:47 AM
reidtool.com, no minimums, lots of good stuff, used them for years.
what you are looking for:
http://www.reidtool.com/digitalfiles/Catalog/2004%20Spring%20Catalog/RFF04_85.pdf
jason
motors: 73.5 911 T targa - RIP, 2005 Subaru Legacy 2.5i
pedals: Ellsworth Truth, Neuvation road bike
Paddles: Dagger Ego
Wind: Liquid Force kites/Ocean Rodeo Mako board
Old 11-14-2004, 01:48 PM
