Price check- lower and align an SC?
Just wondering what a reasonable price would be. East coast in Richmond, Va.
Thanks,
Harold
An alignment should run about $175-200. Lowering is a different story. If your back has to be lowered more than ~1/2" that you will have to get the rear t-bars re-indexed and that can run a lot of labor. I'd suggest get them close yourself and then bring them in for the fine tuning.
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
A 4 wheel alignment in Dallas runs about $150. The lowering is going to vary due to the time it takes to get it right. The guys I have talked to say you need to adjust, then a short drive to get the suspension settled, then measure, and do it again, and usually again, etc..... Time = $, more time = $$$
Jim Dowty 97 911 Coupe (Forest Green metalic, sunroof, leather) PCA RSR region Insurance chair and Board member Gruppe B #309 |
This one will probably need reindexing. I can fit my fist upright between the tire and rear wheel opening and I dont have small paws.
Thanks,
Harold
Banned
oohhhh ahhhh big H with the monster paws........
My cayenne-height SC was lowered to euro and aligned for $380 all in by a mechanic
$250 for the lowering $120 for alignment + taxes, etc.... Adam
Adam, 2019 BMW 540i |
Just had my 930 aligned Friday. Cost: $200 Chicagoland Independent
Just had my Carrera lowered and aligned here in the UK. Was 5-6 hours labour (not sure of the exact time from the invoice as it included some other work). This included re-setting teh spring plates on the torsion bars at the rear.
"Racing is Life. Anything that happens before, or after, is just waiting" 1988 Carrera 3.2 Sport Coupe - my mistress 2012 BMW F11 touring - the dog bus! 2017 VW T6 Transporter - the holiday bus/workhorse |
Ok guys, ignorance is bliss, what's wrong with getting a front end computer alignment at say, Sears, for $59.99????
________________ 78 911 SC Targa 11 Cayenne Base 15 Macan Turbo |
Irrationally exuberant
If you're going to change the ride height you really should have it corner weighted at the same time.
I get mine aligned by a certain guy at a local tire place for $100. I kept him company for the first few times until I felt comfortable with his work. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
UK Carrera do you mean re indexing the torsion bars or actually just adjusting the spring plates?
thnks
Harold
Re-indexing the torsion bars.
I just went through the same thing, although I lowered it myself. It wasn't that bad just took a little time and the only thing I have done to a car before that was replace an alternator. My SC was at the US ride height and I lowered it to the Euro height. 25 in rear and 25.5 in front. Measurments are from the ground to fender lip.
I took in to get a 4 wheel alignment and corner balance and the mech told me my ride height was "nuts on". Not too bad for a first timer. The alignment and CB cost about $300. If you have the space and time, you should try and lower it yourself.
86 Carrera Red/Black 80 SC Coupe Silver/Black (gone but not forgotten) |
How about you PM me your number for an emergency hotline if I give it a try and run into a snag! What part of richmond are you in? Did you use an angle finder, etc..? or just wing it?
Who do you use for a mechanic locally?
Harold
You have a PM!
My lowered before and after
Hi Harold, I responded to your PM.
See my before and after. I didn't go lower the euro and still got a nice result. Adam
I like this low view the best...
Adam,
That's a lot of adjustment. Same as I need. You say the torsion bars were not reindexed in the rear? Can you confirm that with the tech that did the lowering? thanks,
Harold
Sure thing, I'll call him in the morning.
Adam
Hi Harold-
Yes my torsion bars were re-indexed...My guy has been doing them since the SCs came out so for him it goes very quickly but as he just told me you never know what's going to happen when you start taking things apart.... Adam
