peridotian's Avatar
center console delete
I ran AX yesterday at Infineon and sucked but had lots of fun. I have a big bruise on my right leg from grinding into the center console. I am 6'4" and have to sit somewhat oddly to AX. The console has air con controls and audio casette holders both of which are of no use to me. Is this a common delete? Is what is left underneath post-delete visually attractive (the rest of my intereior is immaculate)? Any reason not to do this? Post-delete pics anyone?
Thanks,
Patrick
Patrick Pickerell
www.peridotcorp.com
74 1.8L 914
73 2.0L 914 (motor almost done!)
78 911SC Talbot Yellow (SOLD to a Pelican)
04 BoxsterS with tip (Wifes)
04 C4S!
Old 11-15-2004, 11:56 AM
peridotian's Avatar
Bump!
Patrick Pickerell
www.peridotcorp.com
74 1.8L 914
04 C4S!
Old 11-15-2004, 02:23 PM
No idea, but I want to do the same thing (removed AC already and tapes... ?!) So free *bump*.
Old 11-15-2004, 02:28 PM
ruf-porsche's Avatar
My 74 came without a center console and I pick one up at a sawp meet to install. If you already removed the a/c you can remove the center console. Just a couple of screws.
Old 11-15-2004, 02:57 PM
Designer King
Paulporsche's Avatar
I don't have a pic, but I think I remember a black ribbed rubber mat that separates the carpet continues under the console that at least gives it a finished look. I don't think you would find it offensive.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-15-2004, 03:19 PM
I am 6'2" and also tired of bashing into it. The AC was dead and had been removed so I pulled out the center console. The result was not that unsightly in my opinion.
gary
Old 11-15-2004, 03:55 PM
I am 6'4" and there's no way I could drive with a center console in place. Mine is gone with no air conditioning deck either. Very open and airy. Looks great too. If you really want a pic, e-mail me. I'll go snap one and e-mail it to you. -Bob
Old 11-15-2004, 03:57 PM
Originally posted by Gary Carlton
[B]I am 6'2" and also tired or bashing into it. The AC was dead and had been removed so I pulled out the center console. The result was not that unsightly in my opinion.
Woot - that looks good. Was the carpet already under the console, or did you have to add some? Nice seats too, I have similar seats but in red (and a shade that doesn't match my car very well :/ )
Can bee seen here:
http://bourg.net/~gus/Porsche1.jpg
Old 11-15-2004, 04:01 PM
[QUOTE]Originally posted by gustav
The carpet and mat were already there. The biggest "issue" was deciding on what to do with the wires for the AC switches. I in-elegantly shoved them forward under a mat.
gary
Old 11-15-2004, 04:06 PM
North Coast Cab's Avatar
Gary,
Where did you mount the A/C switches?
John
1985.5 944 GTS
Old 11-15-2004, 04:12 PM
Did you have to muck with the shifter at all, or just remove and replace the shiftboot?
My ac compressor and condensor have been removed by my wrench, but the fan at the very least is still live. I guess I'll just wire nut it for the moment until I can trace the wires and remove them.
Old 11-15-2004, 04:18 PM
John: The AC system was completely removed. The switches were left in the console and the wires left in place in the car and shoved forwards. You can just see them in the left of the pic.
Gustav: Nope. I did not have to even remove the shiftboot. The console held the base of the boot down so I tucked the base under the carpet instead. Worked out pretty well.
gary
Old 11-15-2004, 05:10 PM
peridotian's Avatar
Thanks for the replies. I will post pix after the circumcision.
Patrick Pickerell
www.peridotcorp.com
74 1.8L 914
04 C4S!
Old 11-17-2004, 09:17 AM
na2ub's Avatar
I removed mine and clipped the AC temp control wire back to the harness. For the fan control, I added extension to the wires and zip tied the harness under the dash. I moved the fan control switch to the blank, located just to the right of the steering column. There is not much clearance between the relocated fan switch and the cruise control lever, but they do not touch. Also, you cannot see the fan control switch when seated, but I know where it is. All in all, I am pleased with the results. Now I just have to put the center console back in, if I ever want to compete in PCA Stock Class
Doug
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 11-17-2004, 10:35 AM
Where does one locate a set of those shwanky Recaro's? To digress a bit . . . they kick ass.
Not to hijack, but what's the preferred method of getting a console ('77 w/ factory AC) out of the way for a ball cup bushing change? 101 simply says, "remove console". Thanks.
P. Zimmerman
'77 911S (sold)
Old 12-23-2004, 04:06 AM
drl911's Avatar
Remove the center console and don't look back.
Also think of it as incremental weight reduction. It all adds up, right!
Dan
Can I ask you a question? Sure, what is it? An interrogative statement that tests ones knowledge, but that's not important now....
'86 Carrera . . . '87 951 destroyed by drunk driver ... '01 Boxster S. . . '04 Cayenne S . . .
Old 12-23-2004, 05:17 AM
CBRacerX's Avatar
I've got the late Carrara console with AC controls and Rear Defog, Hazard Lights switches. I am keeping AC but would like to loose the console. Anyone done this yet, keeping everything functional?
Chris
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 12-23-2004, 06:11 AM
drl911's Avatar
I relocated the hazard switch to the main console just to the right of the steering column and relocated the rear window defroster to a "blank" spot between the fog light switch and lighter. The radio fader was non functional so it was just cut and thrown away. The AC was already removed so that was not a problem.
The hard part was that the wires from the hazard switch were not long enough to reach the new location and all 8 (yes 8) wires had to be lengthened. The access to the area next to the fog light switch is through the front hood so the defrost wires also had to be lengthened and re-routed. Somewhat of a PIA, but worth the effort. I can post a picture latter today.
Dan
Old 12-23-2004, 06:56 AM
Jeff Alton's Avatar
When I did mine, I mounted the AC switches in the garbage can!!!!!
Jeff
www.turn3autosport.com
Old 12-23-2004, 08:24 AM
Jeff Alton's Avatar
patzim, three screws and it is out of the way.
Jeff
Old 12-23-2004, 08:26 AM
