8x16 vs 9x17...?
Is there a recommended 'better' setup for front / rear wheel widths? I see wheel enhancement still has 8*16 fuchs, but apparently no 9*16's. So I could put my 7's on front and
end up with 7's and 8's front / rear.
Or, I could go with Lindsey Racing 17's and I assume get 9's.
Then I could go with 7*16 front and 9*17 rear.
Is anyone able to merely widen 7*16's to 9*16's?
I see no 9*16's for sale anywhere...
Is either one of these combinations better or worse for overall
handling (oversteer vs understeer, etc.)?
I really want the extra width, but not at the expense of
balanced handling at the DE's and on the road.
Advice?
Spike
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 11-16-2004, 05:13 PM
rdane's Avatar
The "best" factory fuchs setup for your car would be 8" 944 turbo fronts and 9" 911 turbo rears. 225/245 x16" combo on tires.
They seem to be available in the for sale forum most of the time.
There are also 8 and 9.5 two piece 16" Fuchs and Lindey's two piece 17's as options.
Old 11-16-2004, 05:33 PM
The downside to the Lindsey's 9.5's is that you'll likely need to relocate an oil line (per lindsey's but feel free to verify). they can do the 3 piece in 17x9s with no changes to the car required.
Old 11-16-2004, 06:07 PM
Bill Verburg's Avatar
You might be interested in this page
Bill Verburg
Old 11-16-2004, 08:26 PM
Thank you very much, folks, for the info.
If I go with 7's and 9's will I get more understeer
than if I go with 7's and 8's? Or is the actual
effect nil between the two options?
Spike
Emery
Old 11-17-2004, 05:14 PM
Administrator
Jack Olsen's Avatar
Wheel size isn't going to have a dramatic effect on handling. Tire width, and to a lesser extent, overall tire diameter, will. People generally run 245's on either 8's or 9's. With Lindsey 9's, you can fit 255's pretty easily.
But the point may be moot, as I don't think Lindsey is able to get the 9-inch barrels anymore. I think they can do 8 or 9.5 (or wider) now, but not 9.
If you move the oil line, roll the fender lips, and machine a spring plate bolt, you can run 275's in the back on 10-inch Lindseys.
Old 11-17-2004, 05:20 PM
its my understanding that they can only do the 9's in 3 piece. if you want the welded 2 piece... its 8's or 9.5's.
Old 11-17-2004, 06:34 PM
