collier's Avatar
Any problems with putting '72 parts into a '73 shell
Dear List,
For those of you that have undergone "heart transplant" surgery on your beloved P-Car, are there any fitment issues with transplanting ALL of my '72 parts onto/into a '73 shell ? ? ? ?
My understanding is that there are no differences between the '72 and the '73 ? ? Am I correct ? Still a long hood car...right? No issues with my motor/tranny ?
Any insight would be helpful. I am still trying to find a complete shell to transplant all of my '72's goodies, including motor/tranny/suspension etc. I have found several of varying years, and now it is time to decide on which one to go with....
Thanks in Advance,
C2
C2Motorsports Inc. 502.895.3660 | Engineering | Fabrication | Manufacturing High Performance Automotive Hardware and Software
70 911E*71 911T*72 911T*73 911*76 911 SC- Euro
Old 11-05-2004, 05:20 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
The biggest problem that I foresee is the oiling system. You will need a 73 crossover line, oil tank and S hose and either the front cooler lines, or the line that runs from the crossover line back to the tank. Other than that everything should ,for the most part, swap over.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 11-05-2004, 05:38 AM
collier's Avatar
Excellent...I had not thought about that....
What if I wanted to adapted my 72 external oil tank, filler door, etc. to the 73? That would be pretty cool huh?
C2
Old 11-05-2004, 05:43 AM
Tim Walsh's Avatar
That would probably be fairly labor intensive. You would need to cut out and weld in the oil filler door and probably some tabs to hold it, then adapt the hole that was used for the 73 tank to accept the oil filter console. Not sure about anything more. I'm sure someone else has looked more closely at this.
Tim
1973 911T
2005 VW GTI
Old 11-05-2004, 06:10 AM
I would rather be driving
jpnovak's Avatar
As Tim noted, Everything will fit with the exception of the oil system. Easiest solution would be to use the 73 oil lines and tank. Sure, you can graft the 72 system into the 73 tub. How much work do you want to do? This would require moving all the mounting tabs, filler nect, filler cap, new latch panels etch for release, etc. Certainly not easy.
Old 11-05-2004, 07:21 AM
Bill Verburg's Avatar
It's actually not that hard, when I put flared quarters on my '72 we just cut out the '72 stuff and welded it in to the later quarters, using the original door and hardware. Worked great.
Bill Verburg
Old 11-05-2004, 01:36 PM
collier's Avatar
Sounds like a little updating may be in order......
Thanks for all the GREAT info guys, ya'll are the best
C2
Old 11-06-2004, 07:05 PM
collier's Avatar
I want to thank Aaron of http://www.flat6.com in Minneapolis for helping with my early shell search.....I acquired a stripped, dipped, and primered '73 today...now to get it from Minneapolis to Louisville, Ky.
Anyone coming south with a trailer
Chris
C2
Old 11-28-2004, 08:14 PM
