Poll: Which 17" wheels do you like?
Poll Options
Moses's Avatar
Help me pick my new wheels...
I'm going to upgrade my brakes and put on some 17" wheels. I love my polished Fuchs, but LindseyRacing can't make a 17x9 2-piece wheel anymore. I'm not crazy about all the bolts on a 3-piece wheel. The Fikse's are expensive, but I like the FM5 and FM10. I can get used 10-spoke 996 wheels for a good price, but they will require 1 1/2" spacers in the back. Well, what do you think?
Old 11-20-2004, 09:23 AM
Wandered off somewhere...
Drdogface's Avatar
If you choose to deal with Wheel Enhancement and trade in your Fuchs be prepared to NOT get your so called core deposit fully refunded. Learned from expensive experience.
Mark...
Porsche Boxster S
2012 Jeep Wrangler Rubicon..Crush Orange
Old 11-20-2004, 09:42 AM
Venetian's Avatar
I dealt with WE and they did give me what they said they would(sight unseen) on trade ins which was $100(ea) for 7" X 16" Fuchs. This however was probably on the low side but I did not want the hassle of selling them on my own.
1987 Carrera, Venetian Blue.
Old 11-20-2004, 10:19 AM
Venetian's Avatar
Sorry , those were 6" x 16" Fuchs!
rdane's Avatar
Not what I expect you'll want to hear
I have a set of 930 brakes on my SC. I have a set of 7 and 9 Fuchs from a '86 Turbo finished like yours. Currently sitting in my garage are a pair of 17" Fikse FM10s and a set of 2 piece, custom offset Fuchs.
With the PIA all are with brake clearence, stud length on the factory rims and the resident problems of 3 piece rims and their resulting expensive upkeep ($80. each to reseal them every couple of years) I have a few conclusions for my own use.
225/245s fit with little effort on 16" wheels and are by far the lightest set up mentioned. The perfect setup IMO would be a two piece 8 and 9 with the correct offsets .
and what I like currently.
some weight specs here:
http://quelle911.com/phpBB2/viewtopic.php?p=779#779
Old 11-20-2004, 10:36 AM
techweenie's Avatar
Although I'm not a big fan of spacers, there is a long list of wheels you can use besides the 10-spoke 996. 2000 Boxster S wheels look good on a 911, as do 2001 standard Boxster wheels. some people also like the 993 'Cup' wheels.
There is an early-offset set of 993 Cup replicas for sale here on Pelican, BTW.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 11-20-2004, 10:56 AM
Administrator
Jack Olsen's Avatar
Why did you rule out the 9.5-inch Lindseys? My solution in your shoes would be 8x9.5x17 2-piece Lindseys with 225/255 tires. (They're lighter than stock Fuchs, too.)
Old 11-20-2004, 11:49 AM
Bill Verburg's Avatar
I voted my wallet
But the FM5s w/ black ctrs would be a close second
Bill Verburg
Old 11-20-2004, 12:07 PM
My vote is for the 1--custom fuchs 2--Fikse FM10 3--FM5. All wheels regardless of make will require maintenance/cleaning but those FM5's look really easy to clean but not my fav appearance-wise.
1980 911SC Targa 3.6L
Old 11-20-2004, 12:14 PM
Administrator
Jack Olsen's Avatar
I also have to say: there's something about a black Targa bar and the black Fikses.
Bill's car is one 911 that just wouldn't look as cool with Fuchs.
Old 11-20-2004, 01:58 PM
rdane's Avatar
Cleaning yes and a little maintenance yes. But none of the custom welded two piece wheels like Lindsey's or original Fuchs require new bollts and seals every couple of years to keep air in them as the three piece wheels like the Fikse do. I've seen two pair, no salt on the roads here, both have required a complete service in less than 4 years. At $80 per wheel ($320 for a set plus tax) done at the factory or what ever time and parts it costs you to do it. When they start leaking air I don't consider that "typical" maintenance for wheels.
You get a leak on a set of Fuchs and it is either a nail or you have spun the wheel inside the tire. Those kinds of things I don't mind worrying about
Old 11-20-2004, 02:43 PM
white87911's Avatar
Dont puss out noe, call Andrew @ Weissachin Canada a resrve yourself a set of the RUF 17" wheels that they are having remade. If you have not heard of this, too bad, ignore my message. That makes it all the better for us the have put a deposit on them.
"Coffee is for Closers"
"Push the button Max!!!"
Old 11-20-2004, 05:42 PM
Zeke's Avatar
I want my vote back. That's the best idea.
Old 11-20-2004, 06:10 PM
rdane's Avatar
Better hurry as yesterday was the last day for the deposits to be in.
[img]
Old 11-20-2004, 06:13 PM
Moses's Avatar
Don't know anyone running them on an SC. Lots of folks "think" they would work but Dave Lindsey says no and Bill Verberg's chart indicates it might be tough. I really don't want to shave bolts or move oil lines. If anyone out there is running 9.5s, that remains my first choice.
Old 11-20-2004, 06:31 PM
Moses's Avatar
After reading the other thread, it appears that I can likely make the 9.5's work. It I can, that will likely be my choice. Thanks for all the help!
Old 11-20-2004, 07:22 PM
Administrator
Jack Olsen's Avatar
If you're not in a big time crunch, I'd have them tack-weld you a single wheel, without any finish, and use it to test your backspacing.
Old 11-20-2004, 07:55 PM
