Help me pick my new wheels...
I'm going to upgrade my brakes and put on some 17" wheels. I love my polished Fuchs, but LindseyRacing can't make a 17x9 2-piece wheel anymore. I'm not crazy about all the bolts on a 3-piece wheel. The Fikse's are expensive, but I like the FM5 and FM10. I can get used 10-spoke 996 wheels for a good price, but they will require 1 1/2" spacers in the back. Well, what do you think?
Wandered off somewhere...
If you choose to deal with Wheel Enhancement and trade in your Fuchs be prepared to NOT get your so called core deposit fully refunded. Learned from expensive experience.
Mark... Porsche Boxster S 2012 Jeep Wrangler Rubicon..Crush Orange |
I dealt with WE and they did give me what they said they would(sight unseen) on trade ins which was $100(ea) for 7" X 16" Fuchs. This however was probably on the low side but I did not want the hassle of selling them on my own.
1987 Carrera, Venetian Blue. |
Sorry , those were 6" x 16" Fuchs!
Not what I expect you'll want to hear
![]() I have a set of 930 brakes on my SC. I have a set of 7 and 9 Fuchs from a '86 Turbo finished like yours. Currently sitting in my garage are a pair of 17" Fikse FM10s and a set of 2 piece, custom offset Fuchs. With the PIA all are with brake clearence, stud length on the factory rims and the resident problems of 3 piece rims and their resulting expensive upkeep ($80. each to reseal them every couple of years) I have a few conclusions for my own use. 225/245s fit with little effort on 16" wheels and are by far the lightest set up mentioned. The perfect setup IMO would be a two piece 8 and 9 with the correct offsets . ![]() ![]() ![]() and what I like currently. ![]() some weight specs here: http://quelle911.com/phpBB2/viewtopic.php?p=779#779 Last edited by rdane; 11-20-2004 at 11:05 AM.. |
Although I'm not a big fan of spacers, there is a long list of wheels you can use besides the 10-spoke 996. 2000 Boxster S wheels look good on a 911, as do 2001 standard Boxster wheels. some people also like the 993 'Cup' wheels.
There is an early-offset set of 993 Cup replicas for sale here on Pelican, BTW.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Administrator
Why did you rule out the 9.5-inch Lindseys? My solution in your shoes would be 8x9.5x17 2-piece Lindseys with 225/255 tires. (They're lighter than stock Fuchs, too.)
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
I voted my wallet
But the FM5s w/ black ctrs would be a close second
My vote is for the 1--custom fuchs 2--Fikse FM10 3--FM5. All wheels regardless of make will require maintenance/cleaning but those FM5's look really easy to clean but not my fav appearance-wise.
1980 911SC Targa 3.6L |
Administrator
I also have to say: there's something about a black Targa bar and the black Fikses.
Bill's car is one 911 that just wouldn't look as cool with Fuchs.
You get a leak on a set of Fuchs and it is either a nail or you have spun the wheel inside the tire. Those kinds of things I don't mind worrying about
Dont puss out noe, call Andrew @ Weissachin Canada a resrve yourself a set of the RUF 17" wheels that they are having remade. If you have not heard of this, too bad, ignore my message. That makes it all the better for us the have put a deposit on them.
"Coffee is for Closers" "Push the button Max!!!" |
[img]
After reading the other thread, it appears that I can likely make the 9.5's work. It I can, that will likely be my choice. Thanks for all the help!
Administrator
If you're not in a big time crunch, I'd have them tack-weld you a single wheel, without any finish, and use it to test your backspacing.
