Motronic Chip changing questions
Ok so I have a Euro 3.2 that I am getting to know before it goes into my early car. I bought the engine complete with the brain and harness. I noticed someone has opened the brain in the past so I was wondering if they changed the chip. I pulled it apart and it appears the main chip is fixed/soldered to the board. Shouldn't this be a plug in chip, ie removable?
Would it make a difference if it is a Euro brain? Can anyone tell me if this is the right ECU for a 86 Euro 3.2?
VintageExcellence.com
Old 11-25-2004, 09:25 AM
Here ya go:
Looks like a Euro stock chip. Chip codes all show manufacture date as second half of 1983.
Tim
1986 911 Cab
2008 Audi A6
Old 11-25-2004, 10:43 AM
Driving member
jester911's Avatar
Some of the earlier carreras had soldered chips. It is fairly common.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 11-25-2004, 11:05 AM
WydRyd's Avatar
Nothing a bit of solder wick and a soldering Iron won't fix
Make sure you fit a 24 pin socket in there, if you plan to use an aftermarket CHIP. It'll make it easier to swap in/out in future
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 11-25-2004, 02:53 PM
cool, thanks. I will look for a 24 pin socket. I just wanted to make sure it was the right brain. I'd hate to have the worng ECU.
Old 11-26-2004, 08:46 PM
Lorenfb's Avatar
The 051 DME is not setup for an O2 sensor. If you're in a state which has no emissions
issues or you're using the car as a track-only, then the O2 sensor in not a problem.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 11-26-2004, 09:22 PM
jpahemi's Avatar
Will you get more power without the O2 sensor?
J.P.
Old 11-26-2004, 10:23 PM
