| Registered |
			Noah's article is where everyone starts.  Good stuff. 911s are made to run at high rpms. The race cars need something like 7 to 9K! My build list and some earlier comments that hopefiully will help to put it all into perspective. Quote:
|  11-26-2004, 07:07 PM |
| Registered |
				Re: Noak Pollacks articles.
 If you want to win streetlight drag races and don't want to live in high revs (I can't understand either of those, but to each their own), there is no replacement for displacement. As for me, I love running these cars in the 4-6K range. Who cares about the first hundred feet or so....once you get up there and keep it there, there is plenty of fun. But, to each their own... | ||
|  11-26-2004, 08:03 PM |
| Registered | Quote:
 Reseda Dyno Day - Results Quote:
 Do a search under Tom's screen name emcon5. He has done a bunch of really good comparison graphs for cams and the 3.0/3.2s. try Best Cam Profile For A Stock SC? and http://forums.pelicanparts.com/911-engine-rebuilding-forum/168088-cis-964-cams.html?perpage=10&highlight=20/21 Quote:
|  11-26-2004, 09:12 PM |
| drag racing the short bus Join Date: May 2002 Location: Location, Location...
			Yes, it's a beautiful thing.
				__________________ The Terror of Tiny Town | ||
|  11-26-2004, 09:17 PM |
| Registered |
			Worth noting the better torque curves aren't really a matter of CIS adaptable cams in 3.0s it is the different  valve sizes in the early and late SC heads. That is shown in the torque curve comparison chart. (trust the torque curve shapes more than the numbers)  More HP can be found in the bigger ports of the early heads, more torque in the later, smaller heads. That trend was followed through to the Carrera's 3.2. As many have mentioned 4000 to 6000 rpm is where the 3.0s come alive. Nothing is going to change that short of ditching the CIS and the CIS appropriate cams. You can get more power with a hot cam and carbs but your rev range will be higher and power in an even more narrow band. If you really want torque talk to the guys on board who have the 3.6s or the guy who owns a Z06  . Last edited by rdane; 11-26-2004 at 09:51 PM.. | ||
|  11-26-2004, 09:48 PM |
			RDane - In an Excellence magazine from this summer, Bruce Anderson finally seemed to conclude that the 2R runners (smaller) were more appropriate for the 3.0 engine in stock form than the larger 4R runners which were on the 78-79 3.0s.
|  11-26-2004, 10:13 PM |
| Registered |
			David, guess it depends on what you find "appropriate".  Porsche thought the hp was a good idea over low end torque in the race cars.  When the American market kept complaining about the high reving engines Porsches shipped with, first they enlarged the engines from 2.2 to a 3.0.  Then when even that didn't make folks happy they made the ports smaller to get more low end torque out of the 3.0.  Americans were still looking for a V8's torque....more displacement and smaller ports again on the 3.2...which gave more torque. Torque has always been behind building a bigger flat 6. HP is just a measure of torque, right? | ||
|  11-26-2004, 10:23 PM |
| Registered Join Date: Feb 2002 Location: Chalfont Pa
			I will try thing with the throttle body and see if it is opening fully tommorrow. If my car is in say third gear and I'm driving along at 2500 rpms should I be able to stand on it and go like mad or would it be better to down shift it and floor it. I have found that If I'm not running the car fast it doesn't like when I stand on the gas unless the rpms are already high say 3700 or up. the car dosn't even like to go up hills unless the rpms are above say 3000. With other sports cars I have had. You could drive along at 2500 rpms and not have a problem going over inclines. With this car it will complain alittle bit and even lug if I try and do this.
|  11-27-2004, 01:58 PM |
| Registered | Quote:
 Try keeping your revs between 4-6K. Shift to keep it there. If it means 3rd gear on the freeway, so be it. If you stomp on it, it will go. But it will never feel like low-rev-torque-happy 'merkun iron. | ||
|  11-27-2004, 02:14 PM |
| Registered Join Date: Jan 2002 Location: SF Bay Area, CA
			At 2500 rpms in third, if you want to it to go, you better downshift to second.  >>You could drive along at 2500 rpms and not have a problem going >>over inclines. Were those V8s? 2500 rpms is barely a blip off idle for these cars. | ||
| Registered Join Date: Jul 2000 Location: Daytona, Florida, USA
			After skimming this thread and reading the same advice that is given all the time it seems (all good advice though) I have to say. 1) gear it lower and stay in the upper rpm range 2) 3.6 conversion with Mods 3) get a mustang (good advice already given) 4) get a big block GTO, Chevelle, GS, Cuda ......etc. 5) ride in a V8 converted 911 and see what you think. because as the advice given might imply your can't get there (Torque) from here with a N/A 6 with out $$$$$$. then you will have a high strung engine that will push (but not pin) you back in the seat. I'd go 3.6 with mods and the diet if you want to stay with in the p family. | ||
|  11-27-2004, 02:44 PM |
				 | Quote:
 This could also be, on a more technical level, why Webers have been said to only be good with 911 motors if they are track cars. CIS and Motronic are much better suited for all-around driving.
|  11-27-2004, 02:46 PM |
			Don't get me wrong about the car. I love it and I love how it revs and comes on the cam. neat stuff. Just wanted to see if I could make it better down low. Maybe as I become a better driver I will push it harder and not be afraid to be carrying so much speed into corners and out. So it could be me. I wish or maybe would be wiser to drive at slower speeds accelerating out of corners waiting to see if it slides at slower speeds and still be able to correct. I'm just scared to be at the speeds I'm at when diving spiritedly. Second just wish I could do them at lower speeds and allow the sliding and mistakes to happen at much slower speeds to learn how to correct. When ever I'm at the slower speeds I would need to be in first to get the power I need and we all know that first isn't somewhere you want to be when downshifting and pushing the car the way I want to.
|  11-27-2004, 04:29 PM |
| Registered |
			Sounds to me that what you really need is a little DE.
				__________________ 74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender | ||
|  11-27-2004, 05:04 PM |
| Still Doin Time Join Date: Nov 2004 Location: Nokesville, Va.
			Rdane: was that reading in rear wheel HP /TQ??
				__________________ '15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold | ||
|  11-27-2004, 05:28 PM |
| Registered | Quote:
|  11-27-2004, 06:45 PM |
| Back in the saddle again Join Date: Oct 2001 Location: Central TX west of Houston
				 | Quote:
 You don't need more power, you need more experience and confidence or if the drive for more low end torque is that important then you need a different car. These cars/engines are built more like a highly strung racing engine than a regular car engine, and so they need to be revved. The more you do in the way of cams, free flowing exhaust, free flowing intakes, you are just making the engine build more power at higher RPMs. The odds of you building a 911 engine that will put you back in your seat at 1500 rpm and hold you there until 7 or 8000 rpm are not very good. It sounds like you aren't in the right gear when you are coming out of a corner. Try downshifting. You probably want to have the engine at 3500-4000 or even 4000-5000 when coming out of a corner to feel the pull.
				__________________ Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa  SOLD 2004 - gone but not forgotten | ||
|  11-27-2004, 07:49 PM |
			I guess where I get to drive the car spiritedly is on back country roads that you wouldn't be going all that fast. What happens I want to down shift inot first and that scares  me with the 915. So what happens I'm in second and that isn't low enough. So maybe I just need lower gears in third forth and fifth. Hell I never use fifth unless i'm going over 100 miles an hour!
|  11-28-2004, 12:23 PM |
			Hmm, must be some really tight twisties to not be going at least 35 or so.  You wait for 100 to go to 5th?  Wow, I was in 5th at 70 if I was cruising on the highway.
|  11-28-2004, 02:11 PM |
| Registered |
			No big deal, we all have had steep learning curves with these cars.  Best bet is a PCA DE.  That will answer a wealth of questions very quickly.
|  11-28-2004, 02:29 PM |
