Devil Dog Mosport's Avatar
ER Offset Camber Plate Question ?????
Okay.. just to confirm "what I think is correct"...
Which one is Left and which one is Right? From Pilot's seat
Thanks , anyone?
1984 Carerra 3.2L - SP911
PCA, SCCA, NASA, ComSport
Old 02-24-2013, 09:03 AM
Senior Advisor
James Brown's Avatar
in the picture they are backwards, flip them around.
08 Cayenne Turbo
Old 02-24-2013, 12:55 PM
ah okay... so the bolt holes are closer to the mount on one side and they go inboard to center of car?
Old 02-24-2013, 12:59 PM
proffighter's Avatar
Here is how to mount. This way you get more camber (if desired) easier. Maybe no need for, but mount it this way anyway
Roland
930 Turbo '81 Too many modifications to list
Old 02-24-2013, 01:30 PM
Senior Advisor
correct, the idea is to angle the wheels inboard (at the top) to increase camber - make sense?
08 Cayenne Turbo
Old 02-24-2013, 01:34 PM
Now it does.. thank you sir
Old 02-24-2013, 01:58 PM
just an update on the placement for future reference and straight from "the man"...
If you want more negative camber, arrange such that the bolt holes are towards the outside. Less negative camber, arrange such that the bolt holes are towards the inside.
Old 02-26-2013, 04:08 AM
Sorry, but who wants less than stock camber??? Thats what yo get if switched...
Roland
Old 02-26-2013, 04:40 AM
Pure Racing applications, depending on the track...depending on your driving tactics, your line, and your tires... temp, track conditions.. I could go on..
Old 02-26-2013, 04:42 AM
What racing application asks for positive camber? Stock is
Roland
Old 02-26-2013, 04:57 AM
Clearly you're confused .... If you want more negative camber Positive camber has not entered this conversation..
But, you're right... touche' .. One typically would not want positive camber in the application..
Old 02-26-2013, 05:43 AM
Alex973's Avatar
unless NASCAR?
"IGNITION LEFT OF STEERING"
Alex
Old 02-27-2013, 12:58 PM
Originally Posted by Alex973 View Post
unless NASCAR?
Only if you want to eat the wall at 185mph!
Old 02-27-2013, 01:05 PM
Alex973's Avatar
camber plates
Folks I just bought these from here these do not look
like what you see above can anyone comment chime in please
i do not see any bearings it is just bushings with a 901341018
Alex
Old 02-27-2013, 01:13 PM
These are just camber plates with OEM style rubber bushings.. Stock. What were you expecting? How much did you pay?
Old 02-27-2013, 01:16 PM
Senior Advisor
them stock, the fancy red ones will cost a bit more
08 Cayenne Turbo
Old 02-27-2013, 01:19 PM
