ER Offset Camber Plate Question ?????
Okay.. just to confirm "what I think is correct"...
Which one is Left and which one is Right? From Pilot's seat Thanks , anyone? ![]()
1984 Carerra 3.2L - SP911 PCA, SCCA, NASA, ComSport |
Senior Advisor
in the picture they are backwards, flip them around.
08 Cayenne Turbo |
ah okay... so the bolt holes are closer to the mount on one side and they go inboard to center of car?
Here is how to mount. This way you get more camber (if desired) easier. Maybe no need for, but mount it this way anyway
Roland 930 Turbo '81 Too many modifications to list |
Senior Advisor
correct, the idea is to angle the wheels inboard (at the top) to increase camber - make sense?
08 Cayenne Turbo |
Now it does.. thank you sir
just an update on the placement for future reference and straight from "the man"...
If you want more negative camber, arrange such that the bolt holes are towards the outside. Less negative camber, arrange such that the bolt holes are towards the inside.
Sorry, but who wants less than stock camber??? Thats what yo get if switched...
Pure Racing applications, depending on the track...depending on your driving tactics, your line, and your tires... temp, track conditions.. I could go on..
What racing application asks for positive camber? Stock is 0°
Clearly you're confused .... If you want more negative camber Positive camber has not entered this conversation..
But, you're right... touche' .. One typically would not want positive camber in the application..
unless NASCAR?
"IGNITION LEFT OF STEERING" Alex |
camber plates
Folks I just bought these from here these do not look
like what you see above can anyone comment chime in please i do not see any bearings it is just bushings with a 901341018 ![]() ![]()
These are just camber plates with OEM style rubber bushings.. Stock. What were you expecting? How much did you pay?
Senior Advisor
them stock, the fancy red ones will cost a bit more
08 Cayenne Turbo |
Thread Tools | |
Rate This Thread | |
