Rubatoguy's Avatar
Send a message via AIM to Rubatoguy Send a message via Yahoo to Rubatoguy
G50 backup-light switch
Hello,
I have a 1988 Carerra with back-up lights that will not work.
I pulled the connectors out of the switch on the transmission and shorted them. volia! The backup lights worked.
So I'm guessing that either the switch or pushrod needs replacement. (at $73 I'm hoping not the switch)
Can anyone tell me what wrench size you need to remove the switch and if you may remove it without having to drain the oil in the trans?
thanks,
Todd
'88 Carrera
Old 12-06-2004, 11:56 PM
Not Quite Banned
Thomas Owen's Avatar
Todd,
could not find the size in my books, and I do not think you have to drain the fluid to remove it. Send a PM to John Walker or Chris Bennet and ask them.
Good luck-t
Thomas Owen
1972 911T
1972 911S
Old 12-07-2004, 02:20 AM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
I just replaced mine, I believe you will need a 19mm wrench. You might lose a couple of drops of gear lubricant, but that is about it. Just keep a rag handy, no need to have a bucket or pan.
Make sure you reconnect the wires the same way, as the connectors are shaped a bit different upon close inspection.
Real easy to do.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 12-07-2004, 06:21 AM
fuelie600's Avatar
Ralph,
Will the connectors plug in the wrong way and not work? My back up lights worked until I did an engine drop last year. I haven't had a chance to get back under the car and double check the connectors.
Evan
1987 sun roof coupe
Old 12-07-2004, 06:29 AM
Irrationally exuberant
ChrisBennet's Avatar
AFIK the switch is well, just a switch. Even if you manage to reverse the connections it shouldn't matter.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-07-2004, 07:07 AM
Originally posted by fuelie600
Ralph,
Yes, I think you can plug the connectors in the wrong way but I don't know if doing so will cause the switch to not work. I didn't want to find out! I was just careful to orient them correctly when I installed the new switch.
Ralph
Old 12-08-2004, 10:37 AM
Rubatoguy's Avatar
22mm socket for the switch.
The connectors appear to be the same size - see photo
Old 12-10-2004, 12:41 AM
