16x8 930 wheel/tire question
I have searched the archives but cannot seem to find an answer to my question.
Will a 245/45x16 tire mounted on a 16 x 8 Fuchs 930 wheel fit on an SC. What mods will be needed to make it fit. I have been told it will rub the oil line and the fender.
Justin |
It will fit, no mods are reqiured. I am sure that people will even post some pics to show you what they look like!!
Cheers, Jef
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Picture of 245/45/16 tire on 9 by 16 fuch on Carrera. 8" fuch is very close. Same fender flare as SC's
Yes indeed, 16x8 and 16x9 930 wheels with 245's are a bolt on for the rear.
Todd Doing business with leebparts? http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/555068-attn-leebparts-please-contact-me.html |
The tires/wheel combo fit on my 84' Carrera with one little problem. About a week after they were installed I noticed I now had a shiny spot on the two oil lines just to the rear of the theromstat in the right rear wheel well. I solved the problem with 10mm spacers(one on each side!) that I had gathering dust in the garage. They still clear the fender lips(close, but not touching, nor any evidence of a touch).
In this diagram you can see how far inboard the 9s will be. For the +19mm 9.5s the oil line will certainly need to be relocated.
Bill, I appreciate the diagram. My 84' has the 16x8 Fuchs wheels on the back. When I had the 245/45 16 Yokos mounted it looked close, but I thought it was clear of the oil lines and the fender lip. However, the shiny spots caught me by surprise. I painted the spots black, mounted the spacers(10mm) and remounted the wheels-no problems since. The car is absolutely stock in all aspects of the suspension-maybe the rubbing occured during the action of the suspension moving through its range of motion. These tires feature a rim-protector that protrudes slightly beyond the actual rim edge, which may account for the rubbing. Anyway, I like the setup and the tires.
I wonder if the 245/45 on 8s were flexing more than is normal They should have more clearance than the 9s which I have never heared or seen any sort of issue w/
Anyone have a clear pic of how much a 245/45 bulges on an 8" rim
compared to a 9" ?
David. 85 carrera euro |
