While I had the alternator out...
Stopped racing and became a drummer |
Beautiful, what did you use?
Nick '85 Carrera |
Sweet!
Sweet except the fan won't fit anymore...there shouldn't be powdercoat on the very ends of the tips of the blades....they shoulda been masked. It'll rub the housing......test fit and see for yourself. Then carefully *try* to get it off the ends....
Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Awsome, what did you use. Looks great.
Reverend Ray 84 Carrera Coupe "DAS-V2" GruppeB #2119 Volvo V70SE-Wife mobile Nissan Frontier-Home Depot mobile |
Mine looked the same when it came back from powder coat. It will take a little patience to remove the coating from the ends. I used a new file which helps speed up the removal.
Jeff 1981 911SC Coupe - SSI's + Dansk, MSD, AC delete, Heater Backdate, Euro ride height, polygraphite bushings, Rennshift 1998 F-150 4x4 - Snow Time 1998 Yamaha WR400 - Mountain Ride |
California Proven!
A piece of sandpaper will knock off the coating off the end of the blades in less than 2 minutes. |
My point....coulda told the powder coat place to mask the ends from the outset....saves some later rework.
Wil
I have given my car back it's virginity...well some of it.
The fan looks great installed. There wasn't a problem with clearance, but I did sand the inside of the housing quite a bit. This was simply painted. It wasn't powder coated.
Did you use heat paint?
Nick '85 Carrera |
"A piece of sandpaper will knock off the coating off the end of the blades in less than 2 minutes."
This may lead to chipping of the power coating as moisture can now enter between the power coat and the magnesium (also not good for retaining coatings, moisture causes expansion - not like aluminum).
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
It wasn't high temperature paint. I got $20 worth from a local paint and body shop.
Every now and then I made a poor choice and gas washed the paint off. But, it all worked out as long as I used Rustoleum, Krylon or VHT (on the hot stuff). |
Let's just keep an eye on how well the paint will hold up. The tip speed and local impact of the leading edge of the blades is enormous...and these begin to look rather grody in short order....good luck.
Wil
Banned
i painted mine recently too. it is holding up pretty well. i have got more time than money, so i take it off next year and do it again. thats why i got a blast cabinet eh?
Generally my revs are above 4K so the fan should stay plenty cool
Really, it was just a matter of convenience. I had the paint and access to a painter. He wire brushed the fan nicely and the paint stuck like rock. The tips aren't close to hitting the housing, so all things considered, it should hold up fine. But oh the feeling...it's the little things.
