Engine Knocking under boost
After replacing my turbo to a K27, under around .7+ bar, I get engine knock. Few questions:
1) I first thought it was some thing loose I forgot to tighten. Sounding like rattling. I continued to run full boost for a few times. Could I have harmed the engine? 2) It did not knock with the K26. Does it make sense that the K27 would cause this? 3) How can I get rid of the knock? 4) Can I still drive the car safely but being careful not to boost? Other background that may help: New plugs, dizzy, by-pass valve gasket, new air pump filter. Thank you.
David Nguyen 1987 930: 2700 lbs, 408 RWHP/405 RWTQ 930 pics: http://alturl.com/899f9 930 Engine rebuild pics: http://alturl.com/25qcy |
RETIRED
Timing?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
First, I don't think you had K26 before. K26 is small turbocharger used in Porsche 944, Audi 200 Quattro. Early 930 were factory-equipped with KKK 3DLZ, not K26.
Second, make sure you don't have exhaust or vacuum leak. Sometimes it sounds like knock. Yes, you can damage your engine (it's mostly fractured compression rings) if you run it knocking, but it's impossible to say for sure how long you have to runt it that way to damage it. 3DLZ and K27 are roughly similar...K27 is somewhat more effective. So even if K27 is pumping more air into your engine, it's shouldn't ping at 0.7 bar if 3DLZ didn't at 1 bar. I suggest to check for leaks...exhaust leaks can be checked by applying long rubber-hose to header flanges when car is hoisted on car-lift and motor is running. Also, check everything else that could be bumped during the swap - sticky pre-ignition mechanism, clogged fuel filter etc. Also, it would be a good idea to get it on dyno and check Air/Fuel ratio, or use LM-1.
Thank you for your time, Last edited by beepbeep; 01-02-2005 at 01:32 PM.. |
Chances are it is something to do with the timing. Have you verified it 100%, including the vacuum signal to it?
Matt B '73 911E |
I am guessing you are running lean. The K27 puts more air in your motor and the CIS can't keep up. Did you set the timing to factory specs. If so back the timing off a little. Or get the air/fuel mixture measured on a dyno. Then you can make sure you aren't running lean
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Thanks for the tips. I'll research on this board how to check/adj the timing or af mixture (unless someone's got a direct link to it).
I'm hoping it's an exhaust leak. The K27 didn't mate well with my Monty exhaust. I couldn't get one of the nuts on cause of the angle of the exhaust pipe. So I left it free hoping that the three other nuts would do it's job.
Thank you for your time, |
Super Moderator
Have you verified your boost? The K27 puts out a LOT of boost potentially and this could cause it.
A lean condition could cause it. Too much advance could cause it. Bad gas could cause it.
Somewhere in the Midwest
He mentions a new dizzy so all bets are off...
An exhaust leak won't cause this problem. An intake leak might, depending on it's location. Verify there are no loose or pinched vacuum lines. Also, you mention a 1 bar spring in your mods. How have you verified the actual boost?
Matt B '73 911E |
I tried to test the wastegate using compressed air. I was told the spring I have is a 1 bar spring, but I can only manage about .8 or so (stock). BTW, other than the compressed air test, are there any designations on the spring to indicate what is is? I can't seem to find anything.
If there is an intake leak, would this prevent me from getting a full 1 bar boost and at the same time cause a lean condition? I'll try to do more troubleshooting. Everyone's input has been very enlightening. I love the knowledge of this board.
David Nguyen 1987 930: 2700 lbs, 408 RWHP/405 RWTQ 930 pics: http://alturl.com/899f9 930 Engine rebuild pics: http://alturl.com/25qcy Last edited by porschett; 01-03-2005 at 08:41 PM.. |
Porschett,
Have you considered that it might be a broken head stud? That would cause a rattle under boost and possibly some damage to the head or cylinder. And you did recheck the timing? Just a thought. Tinker |
I did nothing on the timing. I figured a straight turbo swap does not necessitate a timing modification. I'll have to research on how to do this.
Can I continue to drive the car in this state (being careful not to apply any boost)?
Author of "101 Projects"
You might want to try:
1. Check or retard the timing 2. Reinstall the original turbo 3. Run higher octane gas or premix with some race gas 4. Reduce your boost level 5. Check the mixture to make sure it's not too lean. Use an LM-1 unit: http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_exhaus_pg11.htm#item44 -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
One more thought - knocking will indeed destroy your engine if left unchecked. It's the single-most worst thing that can happen to the Turbo motors, and will indeed cause some serious damage, particularly if the car is running lean...
-Wayne
Thanks Wayne.
I'll try the following in order of least complexity: Run higher octane gas or premix with some race gas Check or retard the timing Check the mixture to make sure it's not too lean. Reduce your boost level Reinstall the original turbo
Why a new dizzy too? No offense, but if your problems started with the changes, then target each of the changes. Start checking all the changes you made...eliminate to small stuff first. |
The way I see it, the changes I made can only help (new plugs, dizzy, air pump filter, by-pass gasket). It should not make it worse. Maybe by making it better, I have to adjust things like a/f, timming, etc?
BTW, I changed those items above cause it was time for a 'tune up' and I had the 'While you have it apart, do this" mentality. Plus, it's a great way for me to really get to know the engine. 8)
I'm not breaking down the merit of fixing or renewing parts, but knowing what changes you made should be provide a good path to successful troubleshooting. Good luck.
Hi Guys,
I think I found the problem...the retard vaccum line (black?) is half crimped, limiting vaccum. So at full boost, it's not getting enough retard hence causing my knocking...does this sound correct? Advance (red line?) off boost, retard (black line?) on boost?
David Nguyen 1987 930: 2700 lbs, 408 RWHP/405 RWTQ 930 pics: http://alturl.com/899f9 930 Engine rebuild pics: http://alturl.com/25qcy Last edited by porschett; 01-06-2005 at 10:38 PM.. |
