My first engine pull
John |
UFLYICU
Welcome to the club.
_______________________ Racer Rix Spec911 #5 prc-racing.com Last edited by ZOA NOM; 01-04-2005 at 03:54 PM.. |
Somatic Negative Optimist
Can you post pictures of before and after? Like the dirty engine from all sides?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
I will...the engine is in rough shape....I will be doing the following:
Changing about every gasket New muffler New heat exchangers Cleaning the c_ap out of it New clutch and other stuff.... What do you think about the fan? I have never had any overheating problems...and would like to keep the original Carrera five blade fan...
John |
A lot of people have changed the fan to an 11-blade, but....it's up to you. When you say:" The engine is in rough shape" meaning burning oil? Low CR? Valves? Are you doing a top-end rebuild? Or the whole thing? Are you going pre-74 with SSI heat exchangers? What type muffler? Do you have hydr. chain tensioners? You'll find out if you have Nikasil or Alusil P/C. Have fun.
Sorry, I meant it was filthy, needs fuel hoses, vacuum hoses, cleaned, things like that....it actually burns little oil to speak of...and does not visibly burn it...I ill adjust the valves and replace the seals and gaskets where I can, but I don't think it needs a rebuild. I will have a lot of it apart and make a decision...
John |
Cool. I did my first drop of a Porsche engine last year. Goes pretty easy, doesn't it?
Drop me a line if you need assistance at some point. I am just north of you, near Clio. Wayne
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Will program for food
I know that sh-t eating grin! Mine lasted for a few days... Congrats!
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
The tilting does not look very safe. I would get a lift before I go for it.
Caliber 1987 911 Cabriolet |
OK, OK me too! Mines a little dark , but same story.
Also, be careful with Brake cleaners. Good degreaser - good at giveing cancer.
North 70T Targa 03 Liberty 05 Q-cab 3500 cummins 03 Q-cab 3500 cummins 93 Cherokee - bush jeep 03 and 04 Yamaha Kodiaks 2 of each 00 and 04 Ski-doo Tundras - bush sleds |
Any comments about the ease of engine drop using ATV jack vs. conventional jack.
I need to pull my engine to address oil leaks and I am leaning towards an ATV jack. |
If you have a friend to balance it, the conventional jack works fine. At least it did for me. It would be difficult alone. I built a dolly out of 2X4's with one of the boards high enough so I could slide the jack under. That worked best.
Charlie 1966 912 Polo Red 1950 VW Bug 1983 VW Westfalia; 1989 VW Syncro Tristar Doka |
I never had a ATV Jack. I have always used 2 large conventional jacks.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
