-   -   led RSR Tail lt. assy. (http://forums.pelicanparts.com/porsche-911-technical-forum/200369-led-rsr-tail-lt-assy.html)
lateapex911 05-16-2006 08:36 AM
At the risk of getting an EE upset at something I might be missing, I'll just bring up one concern with that. (Thinking out loud, really...)
If you use a 6 ohm at every corner, the flasher isn't seeing 6 ohms, as it sees more than one resistor in parralel. (If you put two 6 ohm resistors together, you end up with 3 ohms, and so on)
Try doing it up near the flasher.
Here's a kit they sell for this type of thing.
http://www.customdynamics.com/loadequalizer.htm
afterburn 549 05-16-2006 09:00 AM
this might work- freightliner sells a small motorized flasher -it rotates inside rather then typical flasher where heat lifts arm...
Kroggers 05-16-2006 12:40 PM
Jake, maybe I am just demonstrating my lack of rains, but I am confused by what you have said? As long as you have a 6 Ohm resistor between each hot bulb wire and earth, then you are supplying the correct load for each bulb as far as the relay is concerned. It does not mater where you physically place the resistor as long as it is between the hot wire and earth (ie. somewhere between the fuse and the bulb).
Here is a good example from the site that you posted a link to, demonstrating the installation of the resistor http://www.customdynamics.com/load_equalizer_install.htm I will assume that this pack contains 2 resistor with a common earth connector.
Or are you suggesting that the relay should be fitted in series with each bulb and not in parallel with each bulb??
k9handler 07-17-2006 06:22 AM
ok I have Rays 911R lamps mounted but need reverse lights. I have looked at American Superlight and found the 2.5" round LED units...but none of them are clear lense with white light. I want to mount them in my reflector using the gromet like the 911R units. Anyone have a source?
Like this but in clear with white light:
http://americansuperlite.com/images/25210R.jpg
PcarPhil 07-17-2006 06:41 AM
IIRC Ray was able to supply me with a pair of clear lamps. Check with Ray if you haven't already.
k9handler 07-17-2006 06:46 AM
thanks will PM Ray.
afterburn 549 10-16-2006 04:21 PM
will the dude ( Ray ) step up here ? I neeed, I want , I need now evvven. I sent a pm, smoke signals etc
Jack Olsen 10-16-2006 05:06 PM
What about the guy Andy in the UK? The lenses are off-the-shelf units in Europe -- something like 9 pounds each. TRE Motorsports has also carried them.
afterburn 549 10-16-2006 05:14 PM
9 lbs ??? ea ?? mabe you mean 9 oz?? at any rate will try try thanks
afterburn 549 10-17-2006 08:14 AM
found your web sight. will order today, thanks !!
afterburn 549 10-17-2006 08:15 AM
as a side note......W.D. if you stocked these I would have bought them from you
k9handler 10-17-2006 11:47 AM
Sorry it's been awhile since I chimed in...ray did get me the clear units to use a reverse lights and they work very well. THANKS to Ray and to Chris for the lights.
afterburn 549 10-17-2006 12:00 PM
just ordered them from Cris .. not to slight this sight (MOM ) maybe W.D. should carry these too ??? HAY Wayne ???????????????????????????
cstreit 10-18-2006 06:27 AM
Wayne carries the original style 911R lights with the factory Hella incandescents. I'm carrying Ray's LED style.
Hmm... I found them a fairly tight fit, and you can see that Shawn's fit pretty well. THe variation in his is due to the fiberglass bumper. SW, do you have the rubber seals on both top and bottom?
thrown_hammer 10-18-2006 07:26 AM
I invented R lights.
afterburn 549 10-18-2006 08:21 AM
wanted the digits
Formerly Steve Wilkinson 10-18-2006 09:06 AM
I have Ray's R-Type LED lights, which I bought through Chris Streit. The workmanship and fiberglas are excellent and I'm happy with them. Two caveats: If you expect the LEDs to be blow-you-away superbright, you'll be disappointed. They're probalby slightly brighter than incandescents, but not that much.
Also, the fiberglass units fit a bit loosely in the big taillights holes above the bumper. They're held in place simply by the two screws, and one of the screws goes into a slightly kludgy "adapter" that allows for a bit of floppiness. I suppose I could stuff in some thicker gasketing and fix the problem, but currently, I can grab the fiberglass units and move 'em up and down about a quarter-inch.
afterburn 549 10-18-2006 09:09 AM
Well I will give them a critique when done too.
Did someone else fit them for you (and perhaps got too happy with a grinder?)
Formerly Steve Wilkinson 10-18-2006 09:49 AM
Fit them _for_ me??? Hey, i'm Self-Sufficient Man.
afterburn 549 10-18-2006 09:57 AM
me dono..some folks hire everything out...
