-   -   led RSR Tail lt. assy. (http://forums.pelicanparts.com/porsche-911-technical-forum/200369-led-rsr-tail-lt-assy.html)
cstreit 10-18-2006 02:38 PM
Originally posted by Formerly Steve Wilkinson
Fit them _for_ me??? Hey, i'm Self-Sufficient Man.
I thought you just wrote fat checks! :) (joking!)
Formerly Steve Wilkinson 10-19-2006 10:26 AM
Only to you.
PcarPhil 10-19-2006 10:34 AM
Also, the fiberglass units fit a bit loosely in the big taillights holes above the bumper. They're held in place simply by the two screws, and one of the screws goes into a slightly kludgy "adapter" that allows for a bit of floppiness. I suppose I could stuff in some thicker gasketing and fix the problem, but currently, I can grab the fiberglass units and move 'em up and down about a quarter-inch.
Hmm...an adapter? I didn't receive any mounting adapters with mine. What do the adapters look like?
Thanks,
-Scott
Formerly Steve Wilkinson 10-19-2006 10:47 AM
The adapter is an extra $20 and is listed as "Deluxe Adapter," as I remember. It looks like a stick of fibgerglass about four inches long.
cstreit 10-19-2006 11:30 AM
The adapters were out for new tooling for a few months I believe.
PcarPhil 10-19-2006 11:37 AM
Any pics of these adapters? I'm wondering if they're worth ordering to make the housings fit more snug.
cstreit 10-19-2006 01:21 PM
I'll see if I can get some.
k9handler 10-20-2006 11:37 AM
I used a tap and simple made screw holed in the metal where the old mounting bracket sits...the outer mounting points required nothing special. As for fit they are tight...no movement at all and I did use the original seal on the bottom between the light unit and the bumper.
afterburn 549 11-01-2006 08:43 PM
Ok here is my critique . The fit is awesome correct. The holes need to be drilled ( b4 paint). To install- get the longest 10/24 SS you can get ( could not find metric fast enough in my hurry) get plastic nuts for them too (ACE) pull off the backing plat nut holders and replace with the new plastic nut. Place you new R part up there and stick the screws in and you will see that the inboard tab needs to be shoved inboard just a little. and bent to the rear of the car. The out Bord tab needs a tweek too.
Other then that will screw right in to the old mounting spots. PURRFECT.
My only complaint is as far as brightness.....hope the wind dose not blow the candles out. (LOL)
I have a big 3rd brake lt...........but will look around for some better lights to go with these AWSOME R parts.....no grinding or fitting required, just some fuzzz off the inside about 20 sec with 40 grit.
Jeff Alton 11-01-2006 09:10 PM
Whose lights did you buy? LED or incandescent?
Cheers
afterburn 549 11-01-2006 09:48 PM
L.e.d. from Cstreit ( moderator) and or Rays. anyway about 5 post above this one is him
