lateapex911's Avatar
OK, ignore my last post! Looks like I was writing while you hit "submit".
Check your timing. Then start pulling off spark plug wires to see if you can determine which cylinder is not firing.
Double check your firing order.
Ine thing I remember was the rotor interfered with the optical mounts, and clearance was an issue. Make sure everything is seated properly and lining up right in the dizzy.
Dbl check that you used the proper "wheel" that comes with the Crane.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 01-09-2005, 02:18 PM
