Somatic Negative Optimist
Gunter's Avatar
To get fresh surfaces for the balls, it can be done two ways: On each shaft, switch the inner CV to the outer position and the outer CV to the inner position without flipping the CV's. Just picture sliding the outer CV inboard on the shaft, and the inner CV outboard.
I did this on my '80 SC; It should work on earlier 911's. Carreras axles are different because of the stub axle on the wheel side.
Or, switch the axle-shafts so that the left one goes straight across to the right position and the right one straight across to the left position.
Do not flip the shafts to avoid reversing the rotational torque of the shafts!
In other words, the previous outboard (Wheel side) CV's are now the inboard CV's.
Both methods will keep the original rotational torque and prevent stress on the shafts.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-10-2005, 12:08 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Anyone know what size those "Lock Washer" are where I can get them? Our host does not sell them.
Please advise,
I need to replace my Drive Axel Assembly.
'85 Carrera Targa
PCA/POC
Old 12-10-2007, 11:42 PM
smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
Please advise,
Depending on your hardware size. I believe you shoud eitheir have 6mm or 8mm bolts.
You need belliville washers and they can be bought from www.mcmastercarr.com if our host doesnt have them.
You should be alble to find them by searching for "belliville washer" and you want the ones that are serrated on top and bottom and look like the following image.
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 12-11-2007, 12:36 AM
