harry
yes, they do get very rusty - did you read the link i gave you?
Rich ![]() '86 coupe "there you are" |
Using longer bolts is definitely one of the easiest ways to push the covers back. At the same time I did this task, I lowered the front as well and installed the bump-steer bushings. I found out - coincidently, that the bolts replaced with the bump-steer kit are the correct pitch, and long enough, to use for this purpose.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
86 Carrera Red/Black 80 SC Coupe Silver/Black (gone but not forgotten) |
Thanks.
no, thats just for removal of the bars.
mmm, maybe i'm wrong then. i know the G50 or turbo models probably require it....?
Well except for ride height, corner balance and align, my project is done. I will be farming these steps out to Jeff at Rothsport instead of doing it myself.
Some lessons learned: -You got to really pry at them old bushings to get them free of the car. A big flat pry bar seems to be a must. -You need to remove the torsion bar access covers to get the springplate out. -To remove the old bushes from the spring plates, heating the inside of the torsion bar receiver with a propane torch helps to loosen them to the point they mostly slide off. -For the rubber left on the springplates, burning it with the torch is smoky and smelly but makes it much easier to wire brush the remaining material. -The spingplate covers are really grungy inside. I am glad Steve Weiner sugested I get new instead of trying to salvage the old ones. If I had a bead blaster at home, it may have been a viable option to salavage but I did not want to wait several days to try to use the one at work (wife was upset enough with my car spread all over her parking space in garage )-Use of longer bolts to press the springplate covers into place with the new bushes is tedious but effective. -Replacing shock and strut inserts is one of the easiest jobs I have done on the car. -Replacing worn Boge Struts with Bilsteins results in a car with Paris-Dakar ride height in the front. Thanks to all for the advice and help.
Thom - Thanks for the link to the angle calculator. Very handy.
Bill
Bill M 88 Carrera 86 944 SP1 06 Cayman SPC |
Glad to hear it went well! I actuall worked on my covers to remove the "stuff" from inside. In hindsight, new ones would have been much better.
Since you had the spring plates off, you had 90 % of the work done to lower the rear. The fronts are a piece of cake. Any reason why you didn't try to lower the car?
Since, among other things, he has most likely forgotten more than I will ever know about Porsches (and he is the 2003 LeMans GT Technician of the year), I figured it was good advice.
disband
feels cool to have done it yourself eh? nice work.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
An update: For the first time at Autocross (we finally had a dry event!) I did not develop the horrible push I always seemed to experience. I was able to brake later, turn harder and rotate the car almost at will.
For any of you on the fence, updating a tired Porsche Suspension must be worth at least 50 hp on the Butt Dyno.
