She/Her
Look what I got...ok I need help now.
I picked this up for $400!!! All original and came with the decklid. Man what a deal!! Ok, the guy said that the rubber needed to be attached better and he was sure right about that. The outside of the rubber is fine and the inside of the back portion is fine also but the inside of the left and right sides of the rubber are missing their studs and is all dry rotted. Any ideas of how I can fix this little mess.
Gwyneth *she/her 1995 993 Guards Red 1984 911 Targa with a G50 (RIP) |
Better off looking for a good used one in the parts forum or e-bay although new ones on e-bay are usually around $300.
'96 Dodge Viper '09 Maxima '05 zx10..(0-100-0 before your turbo even spools!!) '99 Rottweiler '08 Cane Corso |
Wurth Black Silicone Oil-Resist (or even better 3M Windshield Glue), some creative clamping and screws into the rubber from inside the wing base and you might get a few years out of it. But after that the disassembly might destroy the wing base.
Or, get a new repro rubber surround (~$300)
Chris https://dergarage.com ‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8 |
1.367m later
Beau, call me at the shop. I can help
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
Original Owner
$400 and it needs a new lip cause the studs are pulled and the holes are drilled for the wiper arm and the third-center brake light. And hopefully that number on the deck is just a decal.....yep.... got a deal!!
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
She/Her
Here are the pics you requested Kevin.
1.367m later
No Doubt, thats a factory part. You scored !!
(Quick Edit) The tail base is factory but the deck lid is a normal lid modified to accept the tail.
Administrator
What about inserting new studs, but staggering them between the old locations?
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
She/Her
Hey Kevin, I went to the hardware store to pick up the threaded rod. You said 3/8 but when I saw the 3/8 it looked massively thick. So i got the 5/16 instead. Compared to the studs that are still on the rubber the new stuff is a little thicker than the originals. But the 3/8, I dont think that would even fit in the holes on the tail body. Unless the original studs where ment to be thicker on the sides. Let me know if I did the right thing.
She/Her
Oh yeah to add a little to my story on how i got this tail for such a deal look at the link. The tail started out at $350. average for just a tail. When I looked at the picture, you can see the decklid attached. If you havent been around these tails a lot you cant really tell that there is a decklid even there. Its the angle of the picture that kept others from bidding.
"Formerly Steve Wilkenson" may be better able to describe the large diameter drywall anchor screws ( ?) he used to re-atttach the tail to the base....you know...the kind of screw that loks like a hole-digging auger with the big screw flanges.....from Home Depot....
Steve? - -Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
She/Her
Thanks Wil for the idea but Kevin already supplied me with a great idea.
1.367m later
Administrator
Are these the hardware store thingies that are like a wood screw on one end and a straight bolt on the other?
She/Her
Well, Jack no, I was talking about threaded rod about three feet in length so I can cut up and make studs out of.
