Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Wacky trunk latch issues
Hi all,
If I hit a bump on the highway, or go over a speedbump, my hood/trunk springs open. I don't know much about body adjustments, or even if it's possible to adjust that situation away. Should I look for a new hood latch, or is there something I can do to adjust?
Thanks all!
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 01-13-2005, 12:59 PM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
Thats the million dollar question. If you ever find a solution to this problem you could be a rich man.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 01-13-2005, 02:35 PM
I'd try installing a pick or correct size nail into the hole on the latch body and latch. Fill out the hole as much as possible, not a too thin nail. Then adjust the cable to this. Then make sure the male is adjusted to enter it centered.
for saftey I'd install a temp back up cable in case the adjustment gets screwed up.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-13-2005, 03:07 PM
Rennch on YouTube
rennch's Avatar
Really?? This happens to others?
Michael O'Neal -
Old 01-13-2005, 03:08 PM
Rennch on YouTube
rennch's Avatar
How do I adjust it? Is it the set screw on the wire?
Or do I have to disassemble?
Michael O'Neal -
Old 01-13-2005, 03:09 PM
yes.. don't forget the back-up cable.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-13-2005, 03:11 PM
Todd Simpson's Avatar
Yep. Gets you black flagged too.
Check out the latch first. When in the closed position, does the slider move all the way over?
The pin on the hood is adjustable in every direction. Check that it's centered and try lengthening it a little. It'll go a little deeper and catch better, you'll need to loosen the big lock nut first, then unscrew at the tip.
Old 01-13-2005, 06:01 PM
Rennch on YouTube
rennch's Avatar
Cool, good advice. Thanks!
Michael O'Neal -
Old 01-13-2005, 06:41 PM
Elombard's Avatar
I had a problem with this recently and I think it stemmed from the pin being screwed in too far. This gave the spring alot of pressure and caused it to push the pin out of the latch over bumps. So dont screw the pin in too far. I think this is common with people trying to get the trunk to look closed all the way when lining up the body panels. It turns out on the early cars if you take the front bumper off you can see the bottom of the latch and kind of eye ball how things look from inside the trunk. Also if it gets stuck closed you can get it open easier.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 01-13-2005, 08:10 PM
