Sports Purpose 911 Driver
mjshira's Avatar
Question replacement for clock gauge
I have been looking at a clock that I never use for too long! anybody out there done something cool with that are in the gauge cluster?
greetings from Indiana, the Scruffy skunk works
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 01-18-2005, 02:00 PM
I would rather be driving
jpnovak's Avatar
Hey James, Where have you been hiding? Under the cover of winter?
Old 01-18-2005, 02:04 PM
lally911's Avatar
How about a big red oil pressure light?
http://www.dtmotorsports.com/products/bigredlight/
Keith Lally
85 911 Blue Coupe - gone
84 911 Silver Coupe - gone
Old 01-18-2005, 02:07 PM
Moses's Avatar
Re: replacement for clock gauge
Put a Valentine 1 remote display in a black face (clock-delete option).
mjshira's Avatar
Hey Jamie,
Just been working and getting settled in. Hope all is well with you!
James
Old 01-18-2005, 02:08 PM
addictionMS's Avatar
I ripped mine open and put an extra red oil pressure light and a green alt light in the housing, not pretty, but hey, its a race car....
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 01-18-2005, 02:09 PM
mjshira's Avatar
great idea, a V1 there would be cool!
Old 01-18-2005, 02:17 PM
bell and Overpaid Slacker have gone very creative on that clock replacement. I foreward them this thread.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-18-2005, 02:26 PM
jpnovak's Avatar
I agree the V1 idea is great. Then you could hard mount the receiver to a bracket under the visor clip and run the power wire under the windshield seal.
I was going to mount the switches for my hood lights there. Using an aircraft style locking switch.
I have seen someone place a vent there for additional dash cooling. works great for pre SC cars that lack the dash vent.
Old 01-18-2005, 02:27 PM
mjshira's Avatar
I like the V 1 idea. I was also thinking cly head temp, one gauge per bank?
Old 01-18-2005, 02:28 PM
bell and I used the dual ga mounted on the console. I forgot who did the dual in the clock. You got plenty of options. I'll eventually install 3 fuel psi ga's and maybe a volt meter.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-18-2005, 02:37 PM
oops
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-18-2005, 02:41 PM
mjshira's Avatar
that is cool! thanks Ronnie. As always, you come thru. When are off on your next big trip? Any idea where to get that gauge?
Old 01-18-2005, 02:42 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
see if noho speedo can make you a custom one. put some pics up of dear old scruffy, we miss her out here. hope all is well.
74 911s neverending story. two feet and a jetta for now.
Old 01-18-2005, 03:01 PM
ok.. I just did a search.
mikez in Calif did the single CHT and volt ga. His info is on the 1st site below. The others are good info and some really nice installs from many pelicanheads. You could probably keep finding info by searching
CHT or EGT and RoninLB
Cylinder Head Temperature Gauge
CHT probe placement
Monitoring CHT and EGT
Redundant POS VDO clock died....
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-18-2005, 03:08 PM
I'm in the middle of Bright Idea #4 for my fuel plumbing.. Then I want a full check out at 4k in 5th for a few hrs on I-70 in Utah and Colorado this spring. So either coming, going, or in between We Shall definately get together.. thx for asking.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-18-2005, 03:18 PM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
Losing the CLOCK
Here is what I did. Big Red Oil Pressure light. I will never NOT know when my oil presure is low.
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 01-18-2005, 03:51 PM
randywebb's Avatar
Where are you guys buying those dual CHT gauges?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 01-18-2005, 04:38 PM
the pic I posted is a Westach ga I bought from Aircraft Spruce.. the posted sites give other suggestions.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-18-2005, 04:42 PM
Porsche Junky
mede8er's Avatar
Hmmm....an altimeter would be a cool 'conversation' piece.....
1986 930 RUF equipped
Old 01-18-2005, 05:12 PM
