Sports Purpose 911 Driver
I have been looking at a clock that I never use for too long! anybody out there done something cool with that are in the gauge cluster?
greetings from Indiana, the Scruffy skunk works ![]()
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
I would rather be driving
Hey James, Where have you been hiding? Under the cover of winter?
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Keith Lally 85 911 Blue Coupe - gone 84 911 Silver Coupe - gone |
Re: replacement for clock gauge
Hey Jamie,
Just been working and getting settled in. Hope all is well with you! James
I ripped mine open and put an extra red oil pressure light and a green alt light in the housing, not pretty, but hey, its a race car....
Jim
Jim Hamilton If everything seems under control, your not going fast enough. |
great idea, a V1 there would be cool!
bell and Overpaid Slacker have gone very creative on that clock replacement. I foreward them this thread.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
I agree the V1 idea is great. Then you could hard mount the receiver to a bracket under the visor clip and run the power wire under the windshield seal.
I was going to mount the switches for my hood lights there. Using an aircraft style locking switch. I have seen someone place a vent there for additional dash cooling. works great for pre SC cars that lack the dash vent.
I like the V 1 idea. I was also thinking cly head temp, one gauge per bank?
bell and I used the dual ga mounted on the console. I forgot who did the dual in the clock. You got plenty of options. I'll eventually install 3 fuel psi ga's and maybe a volt meter.
oops
that is cool! thanks Ronnie. As always, you come thru. When are off on your next big trip? Any idea where to get that gauge?
see if noho speedo can make you a custom one. put some pics up of dear old scruffy, we miss her out here. hope all is well.
74 911s neverending story. two feet and a jetta for now. |
ok.. I just did a search.
mikez in Calif did the single CHT and volt ga. His info is on the 1st site below. The others are good info and some really nice installs from many pelicanheads. You could probably keep finding info by searching CHT or EGT and RoninLB Cylinder Head Temperature Gauge CHT probe placement Monitoring CHT and EGT Redundant POS VDO clock died....
Losing the CLOCK
Here is what I did. Big Red Oil Pressure light. I will never NOT know when my oil presure is low.
Mark Scott Vintage 911 Racer 1967 911S 2.4L ROCKET Powered by Faragallah! www.scottassociatesracing.com |
Where are you guys buying those dual CHT gauges?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Porsche Junky
Hmmm....an altimeter would be a cool 'conversation' piece..... ![]()
1986 930 RUF equipped |
Thread Tools | |
Rate This Thread | |
