doozer's Avatar
Kinda Big? I have a SawsAll!
Just kidding.. Thats a good point.. I guess I will see when they get here.
I did a lot of looking around for a set that would take the weight of the car as some of these are just designed to take the stress of the strut, because the spring is in a different location... ie seperate spring perch and seperate strut perch. These are designed for coil over struts on a much hevier car so I should be ok.
Todd
Todd
I drank what? = Party out of bounds - PriceLESS - BudWIZER
"Boy Im gonna burn you a new one! - A new what officer?" = night in jail
993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
Old 01-21-2005, 09:48 AM
project935's Avatar
Can't go wrong with coil-over versions.
Just bump up the thickness of my design if you want them stronger - not a problem with the stud length.
Project935
Tube Chassis Turbo RSR/934/935 racer - SOLD in 6/'06
Gruppe B #101
What's next?
Old 01-21-2005, 10:01 AM
doozer's Avatar
Thanks! I actually got the set that was $154.95
All Tig and 3/16 - and a heim top end to boot!
MORE PHOTOS HERE:
http://hypertec.ws/todd_porsche/photos/air_ride/air_ride.html
Todd
Old 01-28-2005, 09:21 AM
Wer bremst verliert
JohnJL's Avatar
How about an update?
Were they too big?
thanks
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-01-2005, 02:14 PM
doozer's Avatar
Go to my website ( http://hypertec.ws/todd_porsche/photos/ ) and scroll down to "Camber/Caster Box" and you will see what I did to mount them. They worked out great but this requires a willingness to cut and weld on your pcar.
Todd
Old 03-02-2005, 07:20 AM
so, where did you get those camber plates?
WWW.9GEAR.NL
Old 03-02-2005, 03:50 PM
doozer's Avatar
http://store.summitracing.com/default.asp?target=partdetail.asp&Ntt=camber+plate&N=400026&part=HAL%2DCC104MU&autoview=sku&Ntk=KeywordSearch
Todd
Old 03-03-2005, 11:02 AM
Hi Doozer,
I am thinking about fabricating my own camber boxes and liked the QA1 adjusting camber plates that you posted (in particular the price)!!
How did they work? Will the Koni shock fit the bearing hole?
Also the measure that you put for the steel you used, is in inches?
this means 0.25 inches (or 6.35mm) for the top plate?
Thanks in advance for your help,
Mario
Mario
'76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger
'15 GT3
Old 11-06-2006, 01:41 PM
