andrew15's Avatar
Got my ducktail - Question on finish
I just got my ducktail from MA Shaw - Great guy and fast shipping, but... the finish isn't a smooth gelcoat and looks to have been spray painted with a rattle can in spots?!?
Usually fiberglass is gelcoat finished and smooth, but has to be final prepped by the end user. Does Mike pre-fit / finish the edges and shape and then do a bit of spraying?
Just Wondering,
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 01-21-2005, 06:58 PM
andrew15's Avatar
Heres a pic of the back where you can see the uneven spraying:
Old 01-21-2005, 07:25 PM
Noel's Avatar
Just curious if the lid has the center section on the underside that is similar to the stock lids. I have A/C and would need this to secure my AC condensor bracket.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 01-21-2005, 07:51 PM
andrew15's Avatar
Underside reference picture for you Noel:
Old 01-22-2005, 04:22 AM
efhughes3's Avatar
That looks pretty rough compared to what I got recently from The Racer's Group.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 01-22-2005, 05:46 AM
Noel's Avatar
Great. thanks. BTW, does the grill opening accept a standard 1974-1989 grill or the smaller early metal grill. The one I got only accepts the smaller grill that I had to buy.
BTW, that finish does look rough to me, but then again, you should fit it onto your car before finishing it, as you may need to sand down some of the sides to make it fit perfectly. Much easier to do before it has been painted.
Thanks again.
Old 01-22-2005, 05:56 AM
Air Medal or two
afterburn 549's Avatar
get out the sanding block(s) and go after it.....then some high build and the usual
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 01-22-2005, 11:25 AM
1973911s's Avatar
This is what my lid from MA Shaw looked like
1984 Carrera Targa Sold to fellow Pelican
1973 911S Targa - Sold to fellow Pelican.
Old 01-22-2005, 11:37 AM
The ducktail I bought from MAShaw showed signs of sanding on various edges and some waviness on the outside skin below the tail itself at the spot where on the underside the latch support piece attaches. A little disappointing, but somewhat expected as regards fiberglass. The upper corners will also need work to make them more closely match the body opening contours in order to make the trailing edge of the lid match the body edges at the tail lights.
Old 01-22-2005, 11:41 AM
Air Medal or two
I have found tha a old magazine all rolled up and taped makes one great sanding block for anything with curves in it..try it you will like it
Old 01-22-2005, 01:40 PM
andrew15's Avatar
1973911s & Mike - Was there any paint on yours when you got it or was it all gelcoat?
Thanks,
Andrew M
Old 01-22-2005, 01:52 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
here is my MA Shaw ducktail, it came in raw gelcoat no paint and was very easy to put on. took 1/2 an hour.
as the whole car will be repainted when we do the RS conversion in the spring, I left it in raw form.
Old 01-22-2005, 01:59 PM
Mine was just black gel-coated, no paint.
Old 01-22-2005, 03:07 PM
andrew15's Avatar
Thanks guys - I'll call Mike on Monday
Regards,
Andrew M
Old 01-22-2005, 04:22 PM
1973911s's Avatar
No paint on mine, just gel-coat.
Michael
Old 01-22-2005, 04:26 PM
