Me like track days
Yes, you do - I amend my recommendations
Stick with the BFGs.......or go with Yokohama A032rs
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
This thread is worthless without engine specs. cam grind used, specifically.
Andy |
2650lbs and 481 hp.
5.5 per. Revs out (short custom gears for PIR) just after the kink at PR, well before T1, at 156. 370+ RWTQ It's not a project. It's done, sorted, fresh and ready to turn the key and drive, for sale here; Street/Track 930 Last edited by Randy Blaylock; 04-13-2005 at 07:18 PM.. |
Hmmm that is a lot faster than I am going entering turn 1, quite a bit faster!!
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Flat, or very nearly flat through T9 is key.
Don't quite have the stones for that yet, maybe in June when I am there.
Jeff
