Engine type?
My '75 911S has engine number 6152262 and engine type number 911/43 or the 43 may be a 48. Does anyone know if that is the correct engine for my car? It has an 11 blade fan with a sticker indicating it conforms to 1977 emissions standards....
Thanks!
Kelly Bell 72 MGB 75 911S 00 Volvo S70 |
I'm guessing what you mean is engine # 6452262/43 which according to the red book is 911 S (USA 49 State) of which 2,310 were produced. The engine # 6152262 doesn't seem to match up. The 6452262/43 -
90-millmeter bore x 70.4- millimeter stroke 2.7 liter, 2,687 cc k-jetronic fuel injection air pump emissions control 165 hp at 5,800 rpm 167 ftlb torque at 4000 rpm *designated 911/48 with sportmatic (tranny) hope that helps.
"Igneous Aquam et Laudi semper" Carl Muckley |
Kelly,
Welcome to the Forum. It is customary to post pictures of your 911. According to my ’75 Factory Spec Book the engine is a ’75 normal 911 (not S or Carrera). Engine Nr. 6152262 6 = 6-cylinder 1 = 911 (not S….) 5 = 1975 2262 = sequential number The Type number doesn’t jibe. Type 911/41 is the normal 911 Type 911/42 is the 911S Type 911/43 is the 911S/C (USA) Type 911/44 is the 911S/C California 911/46, 47, 48, and 49 are Sportomatics as above. 911/83 is the 2.7 Carrera 210 HP. 930/50 is the 3.0 Turbo. Carefully inspect the numbers. See if they look original or any sign of tampering. What is the VIN on the chassis? Inspect it in four places; driver’s door jamb decal, chassis stamping to right rear of fuel tank, aluminum placard ahead of the RF shock tower, and drivers windshield post. If something turns up suspicious, there is a hidden number. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Thanks guys!
Well, I took a magnifying glass and it is definetley 6452262 and the type is definetley 911/43, so It looks like I have the original engine with a '77 cooling fan abd shroud. How do I post a pic of my car?>
To post a photo of your car, hit the "reply" button, and below the text box, but above the "Submit Reply" button is a link that says "Click Here to Upload a Photo". Click on it, and select the file you want.
If you have a photo up on a website, then hit the "IMG" button above the text box, and past in the URL. Hope this helps! Welcome to the board.
Matt '76 Porsche 911 with '78 3.0 SC engine '71 VW Bus '14 VW Passat (toddler hauler & wife approved ride) '03 Subaru Baja original yellow & silver |
Pic of my project car.
Here is a pic of my project car. It is pretty apart right now. Its a 75 911S
Im far from being an expert but is that a short hood conversion?
Matthew “Sometimes the questions are complicated and the answers are simple.” |
I dont thinkso. It was bought for a girlfriend, who immediatley ubused and neglected it, and It has sat for the past 10 years. its some story. I bought it for $900 in September. Going thru it now...........
$900 did you say $900? That is for FREE
does it run? Man, talk about the right price........i got severe deal envy
Dan '87 Targa |
I haven't started in earnest on the engine yet. I can make it run for a few moments by spraying gas down the throttle bodies, which tells me the FI needs work. there was some corrosion on the body, most of which I have repaired since September. No corrosion on anything structural, tho.
I am just finishing up the front steering, brakes and suspension work, and will start on the rear brakes and suspension next week. Then I will have to decide if I want to tackle the FI myself, or farm it out. Here is a pic of the front steering brakes and suspension build for one of the front wheels. Thanks for the interest!
