"quick reply" vs "post reply" button
the quick reply area at the bottom of each thread seems to take a very long time to post the reply, and more often than not, i get dumped by AOL while it's hanging there. i've taken to quickly copying what i posted, if it hangs, to keep from having to rewrite it if i get dumped. on the other hand, the post reply button to a separate page works quite well. am i just a victim of AOL? does the quick reply require more work from the server, or whatever, in order to function? am i alone here?
Friend of Warren
Been having the same problems using cable internet.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Designer King
I don't know. I can tell you that I am not on AOL and I have never had that problem. Let's see if this quick reply works OK.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Designer King
Worked fine w/ Sympatico (part of Bell here in Canada).
i'm on AOL broadband at the shop.
I'm on obsolete dial-up, using quick reply for this one...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Senior Member
John,
Have the very same problem with Cox cable, and had it last week in a Marriott using STSN, so its not AOL. I do the same "cut and paste" as you do or just give up and hit the Post Reply button and have not had the same problems with it. JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
works fine on dial-up...I think you spotted the problem. Quick reply works best for us on dial-up...
same problem - now (on cable, not AOL) and various times when I had dial-up
I think it is Wayne's server which has been acting up again recently after a few days w/no problems
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Non Compos Mentis
This reply comes to you via "Post Quick Reply" on AOL dial-up.
Pelican BBS has been acting a little funky lately. I've had it hang while posting a reply, and just act slower than it used to. I got some sort of "Network busy" message today during a posted reply. Whatever's going on, hopefully Wayne's on top of it.
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
I've had several "Post Quick Reply" attempts time out off and on over several months. As mentioned earlier, they always seem to post, I just get the error message.
I am here at work on T-? lines so if it fails here, it's a non-ISP problem. My $0.02 -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
Another problem I see is that it often won't take me back to the right place in the thread (the last post made & last one I read)
JW, I just did a quick reply that wouldn't take. The Post Reply worked fine. Normally either works just fine. AT&T.
'80 SC |
Banned but not out, yet..
No problemo with Comcast cable and Mozilla Firefox or IE.
An air cooled refrigerator. ‘Mein Teil’ |
in the early days of Quick Reply I had bs.. I've only used routine reply since. I'm on cable.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
i guess it's post reply from now on.
That is why it is American Off Line
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
