"quick reply" vs "post reply" button
the quick reply area at the bottom of each thread seems to take a very long time to post the reply, and more often than not, i get dumped by AOL while it's hanging there. i've taken to quickly copying what i posted, if it hangs, to keep from having to rewrite it if i get dumped. on the other hand, the post reply button to a separate page works quite well. am i just a victim of AOL? does the quick reply require more work from the server, or whatever, in order to function? am i alone here?
206 637 4071
Old 01-24-2005, 08:54 AM
Friend of Warren
Been having the same problems using cable internet.
Kurt V
Old 01-24-2005, 08:58 AM
Designer King
Paulporsche's Avatar
I don't know. I can tell you that I am not on AOL and I have never had that problem. Let's see if this quick reply works OK.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Designer King
Worked fine w/ Sympatico (part of Bell here in Canada).
Paul
Old 01-24-2005, 08:59 AM
i'm on AOL broadband at the shop.
206 637 4071
Old 01-24-2005, 09:02 AM
pwd72s's Avatar
I'm on obsolete dial-up, using quick reply for this one...
Old 01-24-2005, 09:16 AM
Senior Member
John,
Have the very same problem with Cox cable, and had it last week in a Marriott using STSN, so its not AOL.
I do the same "cut and paste" as you do or just give up and hit the Post Reply button and have not had the same problems with it.
JoeA
pwd72s's Avatar
works fine on dial-up...I think you spotted the problem. Quick reply works best for us on dial-up...
Old 01-24-2005, 09:17 AM
randywebb's Avatar
same problem - now (on cable, not AOL) and various times when I had dial-up
I think it is Wayne's server which has been acting up again recently after a few days w/no problems
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 01-24-2005, 10:35 AM
Non Compos Mentis
This reply comes to you via "Post Quick Reply" on AOL dial-up.
Old 01-24-2005, 02:51 PM
david914's Avatar
Pelican BBS has been acting a little funky lately. I've had it hang while posting a reply, and just act slower than it used to. I got some sort of "Network busy" message today during a posted reply. Whatever's going on, hopefully Wayne's on top of it.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 01-24-2005, 03:14 PM
I've had several "Post Quick Reply" attempts time out off and on over several months. As mentioned earlier, they always seem to post, I just get the error message.
I am here at work on T-? lines so if it fails here, it's a non-ISP problem.
My $0.02
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 01-24-2005, 04:22 PM
randywebb's Avatar
Another problem I see is that it often won't take me back to the right place in the thread (the last post made & last one I read)
Old 01-24-2005, 04:33 PM
JW, I just did a quick reply that wouldn't take. The Post Reply worked fine. Normally either works just fine. AT&T.
'80 SC
Old 01-24-2005, 06:28 PM
Banned but not out, yet..
RSBob's Avatar
No problemo with Comcast cable and Mozilla Firefox or IE.
Old 01-24-2005, 09:49 PM
in the early days of Quick Reply I had bs.. I've only used routine reply since. I'm on cable.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-24-2005, 10:00 PM
i guess it's post reply from now on.
206 637 4071
Old 01-25-2005, 08:30 AM
Jim Smolka's Avatar
That is why it is American Off Line
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 01-25-2005, 08:45 AM
