LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
A fellow Pelacanite
NathanUK's Avatar
Silicon Controlled Rectifier.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 12-28-2008, 04:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
Holly molly, what's a wonderful world. I can rebuild this module in no time with the schematic. thanks u so much.
Old 11-01-2010, 01:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
wwest's Avatar
The issue of "surplus" C8 power/charge. Once the plug's spark/arc extinguishes the ignition coil's magnetic field begins to decay/collapse, voltage reverses and the coil's primary current flows around the "circle" (through the secondary of the inverter transformer) and back into C8.
So C8 ends up already partially charged when/once the inverter restarts. Note that once the SCR is fired, remains fired, the inverter transformer secondary is shorted.
Old 06-23-2011, 06:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
johnman001's Avatar
Which type(s) of capacitors are best for replacement?
I saw that a mylar capacitor could be used for C8, but what should be used on C1-C7?
Thanks a bunch.
John
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?)
1971 914 (TBD)..................... |
Old 08-02-2011, 07:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
never ending projects
niner11's Avatar
This is a cross post from when my SC broke down on sunday but I thought it might be good to show how easy it is to follow Warren's post and replace a faulty CDI C8 cap. Car started on the first crank after replacement. The soldering is pretty easy so I would recommend giving it a shot if you take your time and take pictures during the whole process. Thanks to Warren and everyone else for all of the info in this thread! Chuck
I revised this post because I had to switch the C8 cap to the part from digikey listed a few posts back
Last edited by niner11; 08-04-2011 at 02:12 PM.. Reason: Wrong part initially used for C8
Old 08-03-2011, 02:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
Lorenfb's Avatar
Polyproplylene?????
Maybe guess again!
Bottomline: Bring a spare CDI in the car.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 08-03-2011, 07:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
niner11's Avatar
Lorenfb, thanks for the response. Since your a D$$k 99% of the time I shouldn't expect much from
your posts. It's really pretty simple to fix again or replace with an MSD if it comes to that. Btw, your people skills suck
Old 08-03-2011, 08:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
I am not sure you are in trouble. Let me think about this for a minute but I am not sure you exceed the 150 V/uSec rise time. If you are not at 100 deg C even better.
http://www.wima.de/EN/WIMA_MKP_4.pdf
Rick
88 Cab
Old 08-03-2011, 08:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
niner11's Avatar
Thanks Rick, I can swap out the cap if need be with another suggestion that I had. Chuck
Update: I swapped out the incorrect replacement cap that I used for this more correct one.
Digi-Key - EF6155-ND (Manufacturer - ECQ-E6155KF)
Old 08-03-2011, 10:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
Lorenfb's Avatar
"I am not sure you exceed the 150 V/uSec rise time."
Oh, so that's the only key parameter, right?
Using the same logic: My trans in my 356 SC has an input bearing
problem. Thought I'd use an old VW trans as they are; both 4 speed,
both are trans/axel, appear to bolt-up O.K., so why not give it a try.
I don't think that I over-looked any key parameters or anything that
might be problematic, right? Maybe others on the forum might find
this info useful in solving their trans problem even though I have little
experience and knowledge in fixing/installing a trans. This solution
does seem reasonable, though.
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 08-03-2011, 10:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
So what is the key parameter then?
Rick
88 Cab
Old 08-05-2011, 09:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
I am not sure that is a better part (48 V/uSec) but I am waiting for the Almighty, All Knowing Loren to supply us some useful data.
Rick
88 Cab
Old 08-05-2011, 09:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
niner11's Avatar
I hear ya. I actually PM'd him about a suitable replacement before I did anything but he would rather argue with people than simply provide a solution. Never got a response back from him.
Old 08-05-2011, 10:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
johnman001's Avatar
Want to see the inside of my C8? I too am trying to find a suitable replacement. I saw absolutely no markings on mine.
John Flesburg
Old 08-05-2011, 04:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
Hi there, first post, already looking for help!!
Have a '76 SC with a blown CDI and a will to repair it. I have a blown 31/1 terminal - looks to have got hot and subsequently failed. Additionally I have a burnt R2 (ouch ?!) anyone recommend a suitable replacement / outlet to supply the parts? I've looked about and can only find '10 Ohm 1/4 Watt 5%' rather than the specified '4 Watt' type - am I missing something?
All advice greatly appreciated.
Old 08-06-2011, 12:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
I talked to a capacitor manufacturers applications engineers today and described the CDI waveform and he said Metalized Polypropylene was the way to go.
WTF??
Rick
88 Cab
Old 08-08-2011, 04:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
johnman001's Avatar
Here is what I found:
Mouser 4 Watt, 10Ohm, Wirewound Resistor
John Flesburg
Old 08-08-2011, 07:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
johnman001's Avatar
WTF??
This is what I am going to try. I ordered mine a few days ago. I plan on inserting this into the original metal case bolted back into the stock location. I don't know if it will take the heat though..... I am assuming that BOSCH had these custom made.
Mouser Metallized Polypropylene Capacitors
John Flesburg
Old 08-08-2011, 07:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
OK, sorted the resistor issue, now I need a C1 Capacitor - Siemens 1.0mF 250 volt - rarer than rocking horse poo................?
Anyone suggest an alternative?
Old 08-21-2011, 09:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
How about this one:
B32232A3105K
http://www.digikey.com/product-detail/en/B32232A3105K/495-3529-ND/1647810
Old 08-26-2012, 03:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
