How To Get CHT Wire to Engine
Is there an easy way? I don;t see any openings at all.
John
1985.5 944 GTS |
Hey John, do you mean from the passenger compartment? If so, I have an LM1 setup and found a large grommet in the driver side rear passenger footwell. A few inches up the rear vertical wall(just about where a passenger's heels would be. Nicely shielded from the elements.
Doesn't want/need a 3.6L
Re: How To Get CHT Wire to Engine
Hope that helps a bit. Ralph |
John,
Along the tunnel under the carpet and into tunnel at coupler access cover ... out with the speedo wires and along the top of the transaxle. Hopefully the cable that came with the gauge and thermocouple probe are long enough, because it is very important to use the same type of [J, K] thermocouple wire all the way from gauge to probe! If the cable isn't long enough ... there are extension cables available from Omega, Aircraft Spruce, etc.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
timeless beauty
I would run from engine up, install new sensor, (important) cut old wire at base of old sensor, tape new wire to that and gently pull conector end of sensor up thru engine, clip male / female together.
If that makes sense.
Bob 87 targa |
rc,
I think John is asking about a CHT gauge installation, not replacement of the old NTC resistor sensor for a DME.
timeless beauty
Sorry, I just jumped right in, I was spinning off the pic post.
Bob 87 targa |
It is a CHT gauge installation. I have my carpet out so I have a clear shot back to the engine. I purchased the extension wire so I have plenty of length. I just don't see a good access spot. There are a few grommits, but they are old and hard and on top of the tranny.
John
1985.5 944 GTS |
Ralph |
