Bosch H4 Replacement Lens NOT replaceble?
I purchased the Bosch H4 Replacement Lens from Pelican. I tried to install them today but found the old lens is glued on with industrial strength adhesive.
Is there a way to remove the glue, or did I just waste over $50?
Howard 2003 996tt 1997 911 Coupe Artic Silver (sold) 1988 Black 911 Coupe (gone but not forgetten) |
They're not glued, it's possible the rubber gasket fused to the glass and bezel. Try a little glycerin around the edge of the chrome ring to release the rubber.
J.P. |
Schleprock
plymouthcolt,
I see your signature says your car is a 88. Are your headlights the original units from the factory or have they been upgraded to the European H4 assemblies? If they are the original headlights, then your lenses are H5 lenses. There is a big difference. Take a look @ the bottom, middle of the lens and I think there is the H5 marking above the Bosch logo? The H5 units are indeed those which have lenses permanently affixed to the reflector housing. Translation: if you need a new lens, you must get the entire reflector housing. If your lights are the European H4 units, then ignore what I said. jpahemi is right on. For others who are curious, the H5 is on the left and the Euro H4 is on the right. H4 disassembled
Kevin L '86 Carrera "Larry" |
Kevin:
Do you have any extra retaining H4 springs for sale? Regards, J.P. |
Schleprock
Sorry J.P. No spare springs.
The one pictured was takenapart when I bought them, to see how it's put together. So as long as I went through the trouble of disassembly? Figured i'd take a few pictures.
I couldn't find anything specifally that indicated H4 or H5, so here is a picture.
3.4 Bigger is better
plymouthcolt,
That is the H-5 lens. To replace these you need the reflector/lens unit PP #C-631-909-00 I need to do the same on one of my lights.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
Thanks guys.
Driving member
Not wanting to high jack the thread but are the H-4 lens
and the H-1 lens the same? I need new lenses for my H-1s because they are so pitted. They look similar.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
the refractor design is different between H1 and H4. i see a lot of them mixed up. the bulbs are in different positions between the two types, so the light doesn't get directed to the right place if the wrong lens is used.
Driving member
JW. thanks for clarifying that. I did find the lenses here with our host. I just have a hard time paying 40 bucks apiece.
JW, you never cease to amaze me with your wealth of knowledge of these cars. thanks.
I also need to improve my H4 reflectors. I pulled mine (am 84 Carrera) with H4 lights. Mine were dull, so I bought the bright blue/white bulbs. I pulled the lights and noticed my H4 reflectors had little reflective material left. The new bulbs had little improvement, the reflector is just near non-reflective. Is that part repaceable? Sorry to hijack the thread, my headlights suck (and my ground is also poor, or non-existant). Can I just replace the reflector? Thanks guys...
Big hint from the posted pic....
It's an H5 ( as mentioned)...see "DOT" and the aiming "teets" to aim the lens using US equipment that attches to the front face....I'll bet it says H5 somewhere on the lens, too... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
ricochet:
The H4 reflectors may still be available; contact Daniel Stern, he has good conections in Germany. www.danielsternlighting.com You could also have them replated; I'm in the middle of having a set of H1's done. Regards, J.P. |
Can you pass a state inspection with the H-4 since they are not DOT approved?
Yes, not to many inspection stations check the DOT lens markings; their're more concerned that they function.
J.P. |
Upon seeing this post I was trying to think of the place I ordered my h4 and Carrera 84-89 fog lenses. The url is www.foreigncarpartsonline.com They have Bosch h4 lenses ~$30/piece and fogs for ~$29-$42. Go to the site, click on Porshce parts and enter keyword lens. I think that price is rock bottom?
Rgds, JT -84 targa w fresh repaint |
ricochet:
You can have your old reflectors re-chromed and they turn out great. I had mine done about 2 months ago and they are excellent, I was shocked at the quality. I sent them to: Ideal Custom Plating 937 S 6th Ave Tucson 85701 Toll Free 1-888-878-9090 It cost me $95 for both plus shipping and took about 3 weeks. A little slower than I'd have liked but it was worth it and about 1/2 the price of anywhere else I could find.
Dan O 84' 3.2 Targa |
Chris
Chris '75 911s Targa |
Might have some H4 reflectors in my garage attic if someone needs them. Lenses were broke during a wreck. But I kinda remember the reflectors being OK.
1990 C4 Cabrio 1983 911SC (RIP) 1997 Expedition EB 2004 EXPLORER ( Momma's Car) Zink Z-12 FV ( sold ) 2005 Cub Cadet 1046 |
