Recreational User
DarrylD's Avatar
Check out my "smuggler's box" 10-disc CD player rack
Enough playing with animating engines, how about some sheetmetal fabrication for today's actiivity!
Check out the rack I fabricated to hold my 10-disk CD changer in that wasted space called the "smuggler's box:"
The idea is to suspend the deck in the opening of the "smuggler's box" lid depression.
The "bezel" (the part shaped like the lid of the "smuggler's box" is made of 14-gauge steel, the box is 22-gauge. 14-gauge should be stout enough to bear the weight of the deck without flexing when the road gets rough.
The box in the rack will be water-tight and the seal around the "smuggler's box" lid will seal it from dust. I'll add some adheasive foam weatherstrip to the bottom edge of the "bezel" of the rack to seal dust and moisture out of the trunk.
All that is required to remove the rack to get at the steering linkage is lift it out and unplug the CD deck. The latch of the lid will hold the rack in place when it's closed.
Old 02-07-2005, 06:36 PM
Recreational User
DarrylD's Avatar
Here's the front view, prepped for paint...
A coat of semi-gloss black paint is drying on it as I type...
Old 02-07-2005, 06:42 PM
doozer's Avatar
Looks Awsome!!!
Good job!
Todd
I drank what? = Party out of bounds - PriceLESS - BudWIZER
"Boy Im gonna burn you a new one! - A new what officer?" = night in jail
993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
Old 02-07-2005, 06:54 PM
19 years and 17k posts...
azasadny's Avatar
Darryl,
How much? I'd love to put one of those in my '74 but I'm not nearly as talented as you! Great work! My CD changer is a Pioneer and is probably the same size as your Kenwood. I'm serious, I'd buy one if you sold them!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 02-07-2005, 07:46 PM
al lkosmal's Avatar
Darryl,
That looks nice and functional. Good job.
Al
RGruppe #669
http://www.x-faktory.com/
Old 02-07-2005, 07:56 PM
1987CarreraKid
Guest
Posts: n/a
looks great, i cant wait to see the finished product.
Old 02-07-2005, 08:49 PM
bigrubberjeep's Avatar
Looks great, actually fantastic.
But.........you could just buy a cd player that plays MP3's and burn a single disk that could hold as many songs as the heavy cd changer with 10 cd's in it.
I know, technology suck$.
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 02-07-2005, 09:52 PM
Recreational User
DarrylD's Avatar
Holy cow Art! You think I have the skills to make two exactly the same? My metalworking skills are "organic" and the design evolves as I put it together!
I appreciate the positive feedback!
Ok, did I forget to mention my 911 came with the 10-disk deck and in-dash controller? Oh, yeah, and my 20-year collection of CDs that are already paid for? The total cost of the sheetmetal was $13.
Old 02-07-2005, 10:47 PM
MAS MAS is offline
Nice work. My amp is in my smuggler's box. But it's mounted on a diagonal board.
-MAS
77 911S Targa (current car)
87 924S (my previous car)
Old 02-08-2005, 01:31 AM
You could make a compilation of all your favorites in to one.
Just a thought.
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 02-08-2005, 10:00 AM
doozer's Avatar
Make a box to hold one of these and you could have all the MP3's you would ever want! ( on 80gb hard drive!)
Hmmm... also email and internet..... $500
Todd
Old 02-08-2005, 10:05 AM
Me like track days
Craig 930 RS's Avatar
Really well done!
Makes more sense - IMO - than putting a battery in there and moving the weight distribution further backwards......
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-08-2005, 11:20 AM
Az911's Avatar
Send a message via AIM to Az911
Good job I like it
72T RS look
96 993
Old 02-08-2005, 11:25 AM
js1099's Avatar
Would somebody mind telling this newbie where the smuggler's box is and how to open it. Thanks in advance.
'88 Triple Black Cab - 42K Miles
'01 Acura 3.2 TL
'03 Honda Pilot - EX-L
Old 02-08-2005, 11:54 AM
Work in Progress
Rich76_911s's Avatar
The smugglers box is in the front trunk. To find it simply pull up the carpet, and to your surpise there will be a little door on the passengers side near where the cars black plastic stamped serial numbers are. When you look inside it hopefully you don't find mice, I did, what you should see is part of the steering mechanism.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 02-08-2005, 12:02 PM
Moses's Avatar
Re: Check out my "smuggler's box" 10-disc CD player rack
Great work, but where do you put your weed now?
Old 02-08-2005, 12:06 PM
Recreational User
DarrylD's Avatar
Ok, it's done and installed this morning!
I painted the entire box semi-gloss black, silicone caulked all the seams and then painted the "bezel" with black "wrinkle" paint like that used on electronic component cases.
The threaded mounting bracket holes in the CD-player line up with the holes in the rack so I "bolted" it in to place, hooked-up the 12-pin plug through the case and sealed it with 3M strip caulk (aka "monkey *****" in the industry) so it's water-tight from the bottom. I also put foam adhesive weatherstrip around the underside of the "bezel" to seal the trunk from dust and moisture.
I thought the "wrinkle" paint looked more industrial and wouldn't show fingerprints or scratches like the semi-gloss paint would.
You like?
Old 02-08-2005, 12:08 PM
js1099's Avatar
Thanks Rich, I will go look for weed in it tonight!
'01 Acura 3.2 TL
Warren Hall Student
Bobboloo's Avatar
That's the idea. You think Apple did well with the Ipod. How about run your music, internet, GPS, DVD's and if you were so inclined you could run different maps for your EFI. One for street. One for the track.
"On your mark, get set, go."
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 02-08-2005, 12:10 PM
doozer's Avatar
Re: Re: Check out my "smuggler's box" 10-disc CD player rack
He is having his weed pressed into discs, Disk 7-10, find that copper!
Todd
Old 02-08-2005, 12:13 PM
